DIY Video System for Demonstrations *LINK*
charlie belden
A fellow turning club member and I have been working on putting together a portable three cameras video system for out club. We got to use the basics of the system for our last club demonstration which, coincidently, I did - on turning a miniature hollow form with blended finial. Still have to tidy up the video and power cabling but this things works pretty well. I was run by just one person to do the camera swtiching for what goes to the video projector and to zoom each of the three cameras to get the best view of what's being demonstrated.
One of the things we overlooked when getting used video cameras for the system was the camera remotes. Seems manufacturers use the same remote codes for all their video cameras. Having a remote change ALL your cameras at the same time is a No No. So now we have three cameras from three different manufacturers, each with a remote with unique camera codes.
The attached link has more details on the system we're still working on and at the bottom of the page is a link to a YouTube video on this portable, quick and easy to set up - using NO tools - and run by one person.
Comments, suggestions and constructive criticism of this thing welcomed.
more on this video system with some details
Re: DIY Video System for Demonstrations *LINK*
Charlie I still think this system works well. I can put the camera anywhere it needs to be to best see the action. The downsides are, storage and needing a camera that has remote zoom, and the operator needs to see the big screen to be able to position the camera accurately. It doesn't require any switching. It does require a camera operator who actually cares about operating the camera. Most of the problems we encounter is still the camera operator watching the demo instead of trying to position the camera.
I think a redesign of the basic system and you could make it so it can be broken down into a smaller space for storage.
How many times have you seen a turners shoulder in the video camera when hollow bowls or vessels. You switch to a camera that has a less that best position. With this system you can simply move the camera above the shoulder, even right next to their head if necesssary.
This isn't the whole arm. We add weights to the rear to make it easier to balance the camera. The whole assembly is mounted on a rolling chair bottom so you can roll the camera to help get it into the perfect position. The camera operator is seldom in the way of the audience but it doesn't really matter because you can fill the frame with the tool doing the cutting and everyone is watching that.
It also has the advantage that if the demonstrator needs to step over to a table to do texturing, painting etc, you simply roll the camera over that position.
In my demos I do a section where I walk to the front of the lathe to show how much easier it is to control the tool when cutting a platter (or mirror) downhill with the grain from the center out. The metal "cage" gets in the way of this.
Brad Vietje
Brad Vietje
Excellent post with great details, Charlie!
Thank you for all the time and thought and detail you put into this. I really appreciate the parts and cost breakdown, since I'm a video-simpleton. My local club is tentatively looking into a video setup as the missing ingredient that would allow growth to the next level, so this is very timely.
Without a good video recording/projection system, club meetings and demos are very much limited by the number of people who can cluster around to see what's happening, and often by the limitations of the space itself. If a small theater or surgical teaching gallery with steeply sloped seating in the round were available, we could probably double or triple the number of "good" seats, but without that, they're almost all cheap seats with a terrible view.
In most clubs, we really can't bring in the general public for a big-name presenter, or host larger events for club building or fund-raising. The ability to "zoom in" and show a live video image of very small details is also absolutely essential if the group viewing is more than about 10, and even that number requires frequent stop & inspect breaks so everyone can get a close look, feel the quality of the cut, or see the tool presentation close-up. Those are the little details that are big deals in getting one's turning to the next level.
Your video system -- or one like it -- might be just the ticket. I hope John and others with videography experience (as well as other frequent demonstrators to bring in that angle) will also chime in on the utility of having 3 different (and I think, separate?) cameras, versus something with more built-in integration, or if that is only a requirement of a more seamless-looking video production. I've done demos with 2 and 3 cameras, but only once was the setup adjusted for good lighting without getting in the way of the person at the lathe, and usually I was left to keep moving a magnetic light or a spring-loaded desk lamp that was less than ideal, blocked my view or that of the cameras, and could distract the turner, and even cause an accident at the lathe.
For the moment, effective and inexpensive work very well for me! Thank you again for all the detail in your linked post.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Brad Vietje
Thanks for your experience and wisdom, John!
I wonder if a parallelogram binocular mount would have some utility for single camera video work. I'll find a link and post it here.
In short, this is a mounting system with up to 6 degrees of freedom, which can be counter-weighted to move smoothly. It has another advantage -- as the camera height is raised, it stays aimed at the same spot! This is often used when star-gazing with larger binoculars, so a 3'9" student can aim at something in the sky, and raise the bino's up for a 6'6" adult to look at the same thing with no significant image shift. This won't be as useful for imaging at much shorter-than-infinite distances, but might still be useful to raise or lower the camera to accommodate movement, different hardware, or different tool presentation.
I'll try to post a link in a minute...
Safe spinning,
Brad Vietje
Newbury, VT
Brad The 3 camera systems are pretty good. I've demo at a lot of places that have 2 or 3. However they don't usually zoom in tight enough to really show what's happening. Most of the time your sort of seeing the tool and maybe the shape of the object being turned but you really can't see the tool presentation to the work.
This is where the one camera on a tripod comes in. However if you need to get the camera in the air to get over the turners shoulder, or maybe behind him or even directly over the work to see the cut, it's very hard to do and the camera operator is in the way of either the turner or the audience.
With the boom arm you can pull back and see the whole turner or you can move the camera almost right beside their head to show the cut from the turners point of view. That requires being in close. Usually were not that close of course because you can zoom the camera and have it higher up. The point is you can really get in close at angles that would be impossible with fixed mounted cameras. Sometimes you only need to be a few inches left or right to get the right angle to really see the cut.
Mike Zinzer came up with this idea and I helped with the swiveling mechanism. It needs some fine tuning and I've just been to busy to work with him. I'm going to try and do a video showing how well this system works. You've seen my videos and you see how zoomed in I am on the cuts. They would be even better if I had a camera operator with the boom arm instead of me trying to do it all myself.
Brad Vietje
Brad Vietje
Here are a few photos, and a few links (below) to DIY parallelogram mounts, and a YouTube video that shows one commercial brand, and how it's used. These might be very handy for mounting video cameras for wood turning. For the non astro-geeks, those bino's probably look pretty large; 80 mm and 100 mm bino's are pretty common in amateur astronomy circles. The ones shown here are Fujinon 14 x 100 mm.
I've seen these with parallel frames up to about 5' long, which allow them to easily reach over a chair, and for video work would allow placement over a 10' area without re-positioning the base. Longer arms are usually made with 1" square aluminum tubing -- or 1.5" for heavier equipment.
Here's a longer and lighter version that I think would be great for a digital video camera (these are 80 mm binoculars, which I use) though I'd use a fixed counterweight and not two dangling plumb bobs:
Just for fun, here's a short, heavy-duty version with some really nice 150 mm binoculars:
It would also be possible to add a telescoping arm between the parallelogram and the video head, which would add another level of flexibility. This is not generally done for astronomy work, since we're usually after an even more stable and vibration-free mounting than most video work, since the images are being magnified, and the optical instruments may be quite a bit heavier. 25 x 150 mm binoculars are pretty darned big (and expensive!).
Here's a different design using pipe: http://www.petersonengineering.com/sky/supermount.htm
And here's one using tubular aluminum, which could use a heavier tripod:
http://members.ziggo.nl/jhm.vangastel/Astronomy/binocs/binocs.htm
And here's one using hardwood:
http://www.astro-tom.com/projects/binomount/binocular_mount.htm
And lastly, the YouTube link is below.
Safe spinning,
Brad Vietje
Newbury, VT
Astrowood Parallelogram Mount
Red Wing parallel boom arms
Brad we used these at work. They are great. I made a wooden version to use in my photo demos. Loaned it to a fellow photographer and never got it back. Mike's version is sort of like the parallel arms except you can tilt the front camera support instead of it staying level. I added the swiveling option because tilting alone wouldn't always get the camera in the right position.
charlie belden
John wrote:
>Charlie I still think this system works well. I can put the camera anywhere it needs to be to best see the action. <
The problem is that not every club has a John Lucas available to operate the camera - and who shows up to every demonstration and operates the camera.
>The downsides are, storage and needing a camera that has remote zoom, and the operator needs to see the big screen to be able to position the camera accurately. It doesn't require any switching. It does require a camera operator who actually cares about operating the camera. Most of the problems we encounter is still the camera operator watching the demo instead of trying to position the camera.<
The video system we've put together has the Operator sitting behind the demonstrator - watching all three camera feeds in separate flat screen displays, each labeled and color coded (ie. overhead view, end view and front view) AND a separate flat screen labeled projector (what the audience is seeing). The operator also has three separate labeled and color coded remotes that he or she uses to zoom individuall cameras in or out to get the best shot of the action.
With a display of what each of the three cameras is seeing, the operator has The Best Seat In The House, being able to see three views of what the demonstrator is doing and thus concentrating on the video displays, not on the actual demonstrator.
>I think a redesign of the basic system and you could make it so it can be broken down into a smaller space for storage.<
I'm sure that could be done. But there's still the GOOD CAMERA OPERATOR requirement.
>How many times have you seen a turners shoulder in the video camera when hollow bowls or vessels. You switch to a camera that has a less that best position.<
Even with a three camera system, there's always the possibilitiy of the demonstrator obstructing the view of the Best Shot Camera. One solution would be an additional flat screen display where the demonstrator can see what's being sent to the audience's display (big flat screen or projector screen). The other possibility is to have the "director" inform the demonstrator that his head/should is in the way.
Will add that to our To Do List.
>With this [ boom camera ] system you can simply move the camera above the shoulder, even right next to their head if necesssary<
Again, this requires a good camera operator. And I'm not sure the demonstrator wants anything moving around his head when making a critical cut ; )
> This isn't the whole arm. We add weights to the rear to make it easier to balance the camera. The whole assembly is mounted on a rolling chair bottom so you can roll the camera to help get it into the perfect position. The camera operator is seldom in the way of the audience but it doesn't really matter because you can fill the frame with the tool doing the cutting and everyone is watching that.>
We have and tried a professional Boom Camera system on wheels. But moving it around when there are lights hung over the demonstrator was limited. You don't want to hit the overhead lights - or the demonstrator when moving to get The Best Shot.
> It also has the advantage that if the demonstrator needs to step over to a table to do texturing, painting etc, you simply roll the camera over that position.<
You must have attended one of Jacques Vesery's demos at the San Jose 2012 Symposium. This was exactly the problem with his demo. A possible solution might be to have a small table top that could be quickly and easily placed on the bed of the lathe - in the field of view of the three fixed position cameras - and removed and place on a folding table behind or beside the lathe when not being used.
(another thing to add to our To Do List
>In my demos I do a section where I walk to the front of the lathe to show how much easier it is to control the tool when cutting a platter (or mirror) downhill with the grain from the center out. The metal "cage" gets in the way of this.<
The FRAME we've come up with has the headstock end open. Lookking down on the FRAME, it's an "L". The top of the "L" is over the headstock, the foot of the "L" around the tailstock end. The "L" is about 4' long and only 2' wide. If it were wider, say by a foot or so, you could do what you described without the FRAME getting in your way.
Yet another thing to perhaps add to our To Do List.
Thanks for raising all these points!
charlie belden
We tried a boomed camera, on a pro camera boom set up. For our situation, using a video projector, we need lights over the demonstator - that can be blocked off so they don't wash out the projected video the audience is seeing. I supsect a large flat screen display would solve the lights washing out the display the audience is seeing, but for good video quality, especially for closeups, you need a lot of light.
Were we working in a video studio, where we had all the room in the world and everything needed to produce a perfect demo - and a script that everyone follows, we could get as complicated as we wanted. Unfortunately, we don't have that option - nor do most clubs.
We've also got a storage problem. Not having a permanent meeting place where things can be stored between meetings, everything has to be portable and storable in a small lockable box trailer between monthly club meetings.
Great idea - just not practical for the average turning club.
charlie belden
What I hope WE can come up with is a video system for demonstrations that clubs CAN put together and use - and that's affordable.
I think that such a system would likely increase attendance at Pay To Attend Demos. For our club of 70 plus members, $700 to $800 day long demos require at least 20 people to sign up for and pay in order to get the ticket price down to $35 to $40. But Ticket Price often determine how many people sign up. The lower the ticket price, the more folks are likely to attend. The more attendees, the lower the ticket price.
But the more attendees, the harder it is for everyone to see what's being demonstrated. Paying $25 for a demo you can't see the details of tends to reduce the number of attendees at the next demo so the ticket price for the next demo goes up - and there are fewer attendees due to the ticket price . . .
A decent video system MIGHT break this Ticket Price to Number of Attendees Dilema. And, if every club meeting had a member doing a demo - that this video system was used for - maybe membership would go up. More members, more possible attendees for Pay To Attend demonstations . . .
I hadn't even thought of using a video system for open to the public demonstrations to promote the club and woodturning in general. Promoting woodturning IS one of woodturning clubs objectives.
This Three Fixed Position Cameras With Individual Remote Zoom and Fixed Overhead Lighting idea seems to be workable, based on my collaborator and my experience. But, the more folks looking at a problem, the more likely a Better Way can be found.
Attached is a link to a video we shot using this system. I added the titling and illustrations, but all the turning shots were done with this system. If you watch the video and pay attention to the shots of the actual turning, you'll see that the details of cuts are quite visible. And knowing that there's an overhead camera, an end view camera and a long shot from thef ront camera, you can probably figure out which one was used for each turning shot. I did edit out when my head got in the way - the glare off a bald head being a bit distracting ; )
To be clear, this is not MY video system. Richard Scott, a member of our club who has videographer experience, has been doing all the cameras, switchers, monitors and wiring work. And what we're putting together has been influenced by what we've learned here on WC and other forums. What we're all after is a set up clubs can put together and use. And THAT is going to take a lot of collaboration between folks with different perspectives - video folks, demonstrators and demo audience members. It's the latter folks we're out to satisfy.
Miniature Demo Vid Using This System
Harry Robinette
harry Robinette
My only problem with these systems is your forgetting one thing. If I'm paying to see that turner I would like to SEE the turner and NOT your stand and arms .If I want to see them on a screen then I'll buy a DVD and watch it at home. I understand what your trying to do but things are getting out of hand and getting so you can't see for all the video equipment.
If your putting so much work into us seeing it on tv screens why not see if you could get the equipment out of the line of sight,now that would be great.
Video operators
I agree finding good video operators is difficult. It should not be. As an operator it's pretty simple. Just ask yourself "what would I like to see if I was out in the audience". If you watch the monitor instead of the demonstrator it's very easy. Just say, wow I wonder how he does that cut. You have the camera so zoom in and look. If the demonstrator or in some cases a light is in the way simply ask them to wait a second so you can reposition the camera. Would not bother me and I have asked some pretty famous turners to let me move the camera so the audience can see. They have all been very polite about it and are willing to help.
The trick for us as people who try to set up the equipment is to try to make it simple for the operator. Charlie is doing a great job and I've been to clubs who also did a wonderful job. I think it was the Palmetto woodturners in South Caroline who did a fantastic job. There were others of course but it's almost always the guy behind the camera who makes it work.
We have to constantly work on it. Maybe some day it will be as easy as someone holding their smart phone up over the turner shoulder and transmitting the video real time to everyone else's smart phone so you could watch it from anywhere. Oh well, probably anytime soon but maybe in the next 10 years or so.
Harry I hear that often and even from the front row you really can't see how they are using the tool. Not the fine details. Of course that's why I like the boom arm. The camera person does not get in the way. I think the video should be an enhancement. Remember we are trying to show a large audience who can't all be on the front row, how the turner is working.
Alan Zenreich
Alan Zenreich
Harry,
One of the best setups I've experienced did not have any video. There was a large plexiglass mirror mounted above the lathe and angled towards the audience.
Lauren and I were able to sit anywhere in the audience and see incredible detail BECAUSE we brought along compact binoculars. We could walk around the edges of the room to change viewing angle... It was great, and now binos go with us to all demos.
So not only can demonstrators improve their presentation techniques, but the AUDIENCE can also do things to improve their viewing and hearing of the demo, without 'watching TV'.
Harry Robinette
Re: Video operators
harry Robinette
John
Exactly, that's what I meant it needs to be thought out for the guy that's
watching the demo. Less clutter like the boom camera. Every new system is getting BIGGER and more complex instead of smaller and less visually impacting.
I'm 100% with the idea of having the cameras but they need to make less an impact on the audience.
charlie belden
Alan:
The overhead mirror idea works for some types of demonstrations - a cooking demonstration for example. And the use of binoculars to see details is interesting, especially if you can move around to get a good view. But imagine an audience of 25 or more, all walking around with binoculars, each trying to get the best view, without bumping into other audience members, or obstructing someone else's view.
Using the Overhead MIrror idea, it might be good to put a large flat screen displaying the video feed from the Best Shot Camera - above the turner, facing the audience. But that might block the overhead lights needed to get decent quality video closeups that need a lot of light.
Mirror or flat screen, you'd still need some type of support structure for it.
The thing to keep in mind is that we're after a Decent Video System (not the Ideal Video System)
that
- enhances a demonstration
- most clubs can afford to put together
- doesn't require a professional operator and can be operated by any club member
- that will fit under a typical 8' ceiling height
- doesn't get in the Demonstrator's way
- is quick & eassy to set up and take down
- stores everything together and doesn't take up a lot of room.
Re: Video operators
charlie belden
Using a smart phone camera and "broadcasting" its video to all the other smart phones in the area is interesting - and probably something that can be done NOW.
However - zoomed in, hand held cameras put out shakey video - even with Image Stabilization. There'sa also the cost involved. At $100, minimum for the smart phone, and $40 to $100 a month for cell service . . .
Personally, I'd be distracted, and maybe a bit creeped out, having someone standing right behind me holding a cell phone next to my head, or near were I'm turning.
It might be interesting to have a Gouge Camera - one mounted on the gouge near it's tip . . .
Alan Zenreich
Alan Zenreich
Charlie,
Almost all of the time, Lauren and I were viewing from out seats. Anyone who would roam around the room with binoculars are the same people that would roam around trying to get a better view anyway... but they don't have to come close or get in anyone else's way.
I'm not suggesting binoculars in lieu of a video setup.
I'm suggesting that the audience can do things to enhance their viewing experience (including using binoculars to view the video screen from the back row)
Video is one of several problems that need addressing.
On a related topic, I've been in too many sessions where not only could we not see the demonstrator clearly, but we could barely hear him/her.
I don't have any idea if it will be accepted, but one of my proposals for a 2013 AAW Symposium was for a session on improving audio (while not compromising safety) for turning demonstrators and those making DVDs and YouTube videos.
When I demonstrate, I bring my own (very) portable sound system that works with my safety gear and does not rely on the space's sound system (but can easily connect into any PA or recording devices).
One way or another, I'll share some of the various configurations I've put together... I don't know which form it will take...perhaps in an article, or a video, or a symposium session.
Thanks for sharing your video setup hacking... I'm working on a similar set of recommendations for in-shop (not necessarily portable) setups and am taking a different approach, so perhaps we should chat one day.
Leo Cuellar
Re: Video operators *LINK*
Leo Cuellar
One like this perhaps, relatively cheap & provides video output.
Video inspection camera
Re: Video operators
Lloyd in Mississauga
Great topic,
I know that as I watched demo's when I was starting, I did not know what I should be most interested in what the demonstrator was doing, so I tended to listen more and watch the over all shape of the piece develop.
As time goes on and my skill level slowly climbs, I am much more interested in the actual technique and body/tool position used and the over all shape is not quite as important.
So any video system for a group will have the same issues. You will lose the beginners by getting in to the tool level as many still do not understand why those details are important. Then if you keep zoomed out, the more advanced turners are missing those extra details.
On the presentation screen for some demo's it would be nice to see a picture in picture style display. The larger image being the general interest video, and the smaller detailed image the details. You may need the binoculars (great idea) sometimes, but it may also add to the presentation.
In those cases it may work great if the presenter works with the operator to indicate that you might want to switch the 2 pictures around to show the details better and then when to flip back. The operator could then turn off he P-in-P when it is not needed.
Lloyd
Alan Zenreich
Re: Video operators
Alan Zenreich
Lloyd,
I agree, and the configurations I'm testing support PiP (picture in picture) as well as other very useful video tools.
I hope to share my findings with others as soon as they've been tested in a few more shops.
charlie belden
>On a related topic, I've been in too many sessions where not only could we not see the demonstrator clearly, but we could barely hear him/her.<
Our venue has the audience fairly close to the demonstrator, and our members are not shy ; ) If someone can't hear what the demonstrator is saying, he or she will definitely speak up. And most demonstrators can project pretty well.
For larger venues a wireless mic, amplifier and speaker is a good idea. Of course, if a full face shield, or respirator mask is being worn, getting a wireless lapel mic to work poses a problem.
>I don't have any idea if it will be accepted, but one of my proposals for a 2013 AAW Symposium was for a session on improving audio (while not compromising safety) for turning demonstrators and those making DVDs and YouTube videos.<
The more of the audience's senses are engaged, the more information can be conveyed and hopefully absorbed by the audience. For smaller audiences, say 20 or 30 people, the demonstrator's voice can usually be heard pretty well - assuming he or she speaks up and doesn't mumble. When its 50 or 60 people in the audience, amplifying the demonstrator's voice is essential.
When EDITING video with sound, for a DVD or YouTube video, the sound complicates the editing process when assembling clips. Many demonstrator's keep up a running banter while turning. And in that banter may be a few gems of really important information. But those gems are often dropped while something boring to watch is being done. You want the "gem" - but not the boring video. Working the GEM into an edited down video can be a lot of work. It can be done, but it's a bit more work and requires a better understanding of the video editing software being used.
>When I demonstrate, I bring my own (very) portable sound system that works with my safety gear and does not rely on the space's sound system (but can easily connect into any PA or recording devices).<
Seems adding a wireless mic and a portable Boom Box to a club's Video System would be a great idea and wouldn't add much to the system's cost. Of course, "wirelesss" means battery powered - and that means someone's got to charge the batteries before the demo, or to keep a lot of spare batteries available.
>One way or another, I'll share some of the various configurations I've put together... I don't know which form it will take...perhaps in an article, or a video, or a symposium session.<
Maybe Ellis would be willing to include articles on this subject in the Articles Section of WoodCentral. If not, I'd be happy to host it on my personal (as opposed to commercial) woodworking site.
>Thanks for sharing your video setup hacking...<
I'm just doing the physical "packaging". It's Richard Scott that's doing all the audio and video hardware selection and integration. He's the one who knows what to look for when it comes to finding used cameras at a good price.
>I'm working on a similar set of recommendations for in-shop (not necessarily portable) setups and am taking a different approach, so perhaps we should chat one day.<
The more interested and knowledgable people working on a problem, the more solutions are likely to be found. Collaboration can be really helpful.
Send me an e-mail and let's set up some time to talk on the phone. I don't type that fast , but I can talk pretty well ; )
my e-mail address is
charlieb@accesscom.com (that's two COMs and one DOT)
Re: Video operators
charlie belden
In those cases it may work great if the presenter works with the operator to indicate that you might want to switch the 2 pictures around to show the details better and then when to flip back. The operator could then turn off he P-in-P when it is not needed. <
Showing the audience multiple views of what the turner is doing would certainly be great to have - for the reasons you pointed out. Not being a Video Geek, I don't know what would be required to add this feature - live, but it would probably add significantly to the cost of the system and make the Director's job more complicated.
I do know that most video editing programs / applications / apps let you do Picture In Picture so adding PIP to a DVD or YouTube video can be done pretty easily.
A neat option in most video editing apps is the ability to flip the video over. Normally, on a overhead shot, you're seeing what's going on - from the audience side. By flipping the video over, what you see is pretty much what you'd see if you were the turner, no mental gymnastics to "get" what you're seeing.
Alan Zenreich
Alan Zenreich
Charlie,
When I come up for air, I'll be happy to contact you and set up a call.
Alan Zenreich
Alan Zenreich
"For larger venues a wireless mic, amplifier and speaker is a good idea. Of course, if a full face shield, or respirator mask is being worn, getting a wireless lapel mic to work poses a problem. "
Charlie,
I agree, and that's why I've come up with alternatives that do work with my powered respirators and face shields.
I've discussed this with several professional demonstrators. It is my contention that the professional demonstrator should bring along audio equipment that works with his/her gear, fits properly, and is familiar to and controlled by the demonstrator. It's similar to the turner bringing his/her own gouges and not relying on hand tools supplied by the venue.
I consider this part of the "uniform" and tool set that should be simply part of the traveling gear. The turner should not have to rely on (and often later apologize for a poor) audio setup at the venue, and should be able to plug into good setups.
Consider it a way of making for a 'better performance'.
Granted, this is a bit of overkill for the occasional demonstrator (and might be a good investment for the venue), but for the pro that demonstrates on a regular basis, I believe that good audio should be part of the professional toolbox.
