Wine stopper display
I had to make a wine stopper display rack for a gentleman to give as birthday gift. He had seen my display at the craft center and wanted me to make something. I wanted to do something different and completely turned so I came up with this. I glued together 2 walnut platter blanks that I had laying around. I had to flatten the face which is where the scraper discussion started.
I turned 2 rings on one side and parted about half way through. Turned a rebate for my chuck and flipped the assembly over. Then I turned the same 2 rings on the other side and finished parting them off one at a time.
Then I mounted the rings in my Jumbo jaws and cleaned up the inside which was the parting cut.
Cut them apart on the bandsaw and rounded some edges on the disc sander. Drilled all the holes which was a challenge. Because of the tapered shape I had to drill from the inside of the circle. That meant the drill would probably tear out wood on exit.
The top isn't completely flat so I cut out a scrap of plywood to roughly match the shape of the arc. I filled this arc with body putty and then coated the walnut with wax. When the putty started to set up and get thick I pressed the walnut into the scrap wood with the putty in it and let it harden more. This gave me an exact copy of the face of my walnut pieces so I could drill through and the exit hole would be supported and not tearout. Well it did on a couple anyway but minor enough that I could carve them out after I routed the top of the holes.
The pieces are held together by short pieces of Drill rod that are epoxied into the outside holes. This thing will fold up for storage since the middle ring doesn't have any epoxy.
