glue for plastics OT
bill crommett
I need to glue some grab bars to the plastic surface of a shower enclosure. What cement will hold fast and not leave a discoloration at the edges.
bill crommett
Re: glue for plastics OT
Stuart Johnson
Bill, I wouldn't trust any glue for shower grab bars. They should be anchored into studs for safety.
david
According to accessibility standards, a handrail should be able to withstand 250 lbft in bending, shear, or tensile forces. In most residential construction, a backer piece needs to be installed behind the mounting point through drywall, or fastened where a stud is located.
bill Crommett
The question was NOT answered.
The grab bars in question are not for any moment of force, and are only meant to give a reference for balance. Because I have severe inner ear problems my balance requires a visual reference which is not available with soap suds in my eyes, or water running down my face during shampoo rinse.
david
Bill:
Under the parameters you describe, you need to be aware that what you are attempting is not recommended for use by persons not familiar with its limitations. My recommendation is to use a lightweight grab bar and use through fasteners with large washers to spread the tightening forces. The plastic shower panel should be capable of drilling holes through for the fasteners if done carefully (slowly) and at low speed. If one fastener at each end of the grab bar plate will support the bar, I would use just one, as more holes will weaken the area. Use non-ferrous fasteners at least 3/16" or 1/4" in diameter. An acorn nut on the bolt is also a good idea. A fender washer with a thin neoprene gasket of the same diameter against the plastic is what I would use.
Stuart Johnson
Bill, sorry about not answering your question but unsecured grab bars are just too dangerous. I'm sure you can find some sort of glue or epoxy that will work. I would like to make another suggestion. If it is a visual and perhaps tactical reference you can use a thin strip of decorative tile. They would give you a contrasting visual reference and stick out enough for your fingers or hand to feel.
FWIW, I suffered from both Menier's and inner ear crystal imbalance for a number of years. For me just being able to touch something know (handrail, table edge) would handle the vertigo. Thankfully (?) I finally went deaf in my one ear and the vertigo for Menier's stopped. I went on for many years with the crystal issue thinking it was just a side affect. When I finally mentioned it to my current doctor he sent me to a therapist who fixed the problem with just three sessions.
