A special turning - need some help
Craig Daymon
My best friend passed away recently and I'm attempting a memorial piece. (He went in for hernia surgery and they found he was in the final stages of cancer.)
I have to turn either some ebony or some blackwood for this piece. The ebony piece I have is the right size, but it may be wet. (Just bought it yesterday and it was heavier than the other pieces of the same size. It's heavily coated in wax.) I only have a short time to complete the project and it is something I want to last forever. (Or at least until the US becomes a civilized country and adopts universal healthcare...OK, let's just say forever.)
I'll use epoxy for the gluing. Any other considerations? Tips on turning ebony (or blackwood)? Drilling? (I have to drill a hole through one of the pieces I'll be turning.)
Also, I'd like to cut out some symbols from aluminum (1/8" thick) and embed them in the turned ebony/blackwood. Any tips on doing so would be greatly appreciated. The surface will be curved. Think teardrop.
Here is a link to a video of Jim showing some of his artwork at the Rockford (IL) Art Museum. Some parts are turned, so it's applicable to the forum. As much as he looks like Santa, his heart was twice that size...and always was (no grinch transformations here).
http://vimeo.com/6058089
Thanks,
Craig
Re: A special turning - need some help
Harry in Beautiful Downtown Kulpsville
I've never turned Blackwood but from what I've heard it is easier to turn than ebony. I've turned some ebony and found it to be very 'chippy.' So, if you want to keep a sharp edge on the piece, keep your tools really sharp, sneak up to the final dimension slowly and turn the lathe speed up within your comfort range. This has worked for me in the past.
john lopez
Ebony can be brittle so very sharp tools are a good idea.
Remember to use slow sanding speeds to reduce the chance of cracking.
Somebody here mentioned that trophy shops can do laser etching on some materials,
might be an option for the metal inlays.
I don' t turn much ebony or blackwood but can tell you that you need light cuts and sharp tools.
I can help with the inlay. Glue the inlay down very lightly with just a drop of CA. Scribe around it with an extremely sharp pointy tool. The lady that taught me actually stropped the end of the more or less a needle but stiffer. Then break off the glued on metal and rub chalk into the traced cut. This makes it easy to see. Then use a router, carving tools, whatever you have, and go slow and carefully to the depth you need. route right up to the line being very careful to not go over it.
For small pieces I use a drop of so of epoxy. I try not to use any more than it takes. If the piece fits well into the opening the epoxy won't have to do any real work.
The gunmaker who also taught me some techniques used pins or short homemade nails made of the same metal. He would drive these through and then then file and sand them flush. You can barely see them. I haven't used that method so far.
If it's going to be an inch or more I use Leech f26 that you can usually buy at the Hardware store. The only problem with it is it's tan so you have to be careful and not let it get anywhere near the edge. It stays flexible forever I guess. I had a lamp I made 20 years ago. The wood broke so just for the heck of it I peeled the metal laminates off. The glue was still flexible and the metal was still stuck.
Bill Howatt
I've turned blackwood. What has been said about the tools being sharp is right on the money and be careful to keep the bevel rubbing or it'll grab very easily with brittle little pieces being broken out.
If for any reason you are having trouble try a scraper - it works very well on the hard, hard woods.
Bill
Craig Daymon
Thanks for all the advice.
I'm using the ebony. It's turning pretty well. If I take a heavy cut, it chips, but lighter cuts produce nice curls. Getting it done by Saturday is going to be a challenge. (What with this stupid 40 hour/day thing I've got going on.) I'll try to post pics soon.
Thanks again,
Craig
P.S. I don't recall if I sent an email to Keith Tompkins or Mike Stafford a while back about an idea I had and some special wood I needed to make it work. This piece I'm making plays off of that idea. A few missteps along the way (bit too much dye), but I think it worked as expected.
