How do I glue latex to pvc?
Chuck Jones - West TN
Some time ago I saw the suggestion to use latex surgical tubing as a gasket for homemade pcv vacuum chucks. Took me forever to find it. (Lowes had it about 2' above my line of vision). I slit it and it fits nicely over the rim of the pvc, but I don't know how to attach it. I tried pvc/cpvc (plumbers) glue but I might as well have used oil. Maybe silicone?
Re: How do I glue latex to pvc?
Chuck I've had some success with clear silicone caulking that I use for my mirrors. It works pretty well but starts to fail after 5 years or so. It's really easy to reapply however.
Another good product is Leech f26 that you can usually find at the hardware. It's messy to use but is a really good all around glue. It stays flexible and holds well. I use it mostly go glue metal to wood but have used it in the past to glue rubber to PVC.
Stuart Johnson
I use foamies from Wal-Mart for my gasket. They need to be replaced after a couple uses but they are cheap. I don't think you need to glue the latex. With a slit it will have enough holding power from the tube trying to close to prevent it from falling off, the vacuum will hold the piece tight to it and the pvc.
Chuck Engstrom
Hi Chuck -- you could try 3M 5200, a polyurethane caulk used widely in the boating business. It takes several days to cure (there is a "fast" version too) but will stick almost anything together. Clean up with alcohol, acetone, or lacquer thinner. Very tough stuff -- don't use it if you think you'll ever need to disassemble. There are similar products from Sikaflex and others too. 5200 is often available at big box and local chain hardware store.
Best--
Chuck
Phil Stivers
Phil Stivers
I've heard that E6000 will bond almost anything. I have some but haven't gotten around to trying it.
Dennis in Southern Oregon
Chuck, I tried several types of cement when I was making my Vac chucks, and the best I found was neoprene wet suit glue. A google will give you many sources.
Dennis
Phil Powell
Here's another thought, I just purchased the "Rubber Chucky" silicone gaskets for
The three different sizes of plumbing fittings and I have to say they work great!
I was tired of the sticky back foam and tubing ideas and these gaskets are made
For the fitting you are trying to use. You'll like them.
Phil
Most silicone sealers, like Shoe Goop,......
JamieDonaldson
....should work well for this application, and are almost universally available.
Thanks for your help...
... this gives me several options to try. "Shoe Goop". Boy have I been leading a sheltered life. Never heard of it before. I searched it on the net and found an interesting story.
The foam pads from Hobby Lobby, Wal-Mart etc. work fine on my smaller sized chucks. I have one 6" diameter and the foam keeps coming off that one. I think this tubing will work better. It actually does hold without adhesive while under vacuum, but falls off under normal handling.
Thanks again.
Re: Thanks for your help...
Keith Newton
I was thinking rubber cement, or even contact should work.
