shop lights
shop lights
shop lights
darrin hill
well.. i posted photos of my new shop last year, and someone said my lights needed a shield or grid to keep wood from flying into it..
couple of nights ago i had a HF splode and become one with the universe, and it took one of my 4ft florescence tubes with it,.
i could just build a frame and cover it with 1x1/2 welded mesh, but was wondering if someone had better ideas or knew where you could get something to protect your lights...
Re: shop lights
Re: shop lights
Bill Youngblood
Most fixture manufacturers of shop lights have optional safety shields available. You might have to go to the manufacturer or a real electrical wholesale house rather than one of the big box stores. You may have to upgrade your lights. Worth a shot. Good luck.
Re: shop lights
Re: shop lights
Terry Scott
I just fit the ones that come with a plastic cover as the plastic has enough give to bounce most flying objects off them.
Re: shop lights
Alan Zenreich
Re: shop lights
Alan Zenreich
Most home centers carry clear plastic sleeves that fit over each 4' tube. An inexpensive piece of safety gear.
Re: shop lights
Re: shop lights
I don't have any flourescent lights in the line of fire for my lathe. I use task lights at the lathe. It gives much better lighting for finding those #@$%^ sanding scratches and I can reposition them to see better. I do have lots of flourescent lighing overhead it's just not that close to the lathe.
Re: shop lights
Re: shop lights
Scott Crumpton
I'll second this suggestion. I consider the florescent tubes as acceptable collateral damage, but I really want to contain the mess from a broken one and the plastic cover tubes work great. I have these tubes over all the lights that are "within range" of me hitting them while moving stock around. One suggestion - Use a little packing tape to secure the end caps so they don't come off. Then, when the inevitable occurs, simply tape over the small holes at the ends and dispose of the whole mess without ever opening it.
Re: shop lights
Dick Hines
Re: shop lights
Dick Hines
I mounted 2 Moffett lights onto my lathe. It is nice to have all that light where I need it. Now the problem. I was useing 100watt bulbs. While turning a bowl I smelled smoke! I looked up and some chips had gotten into the Moffett lights and were smoking!! I quit what I was doing, cleaned all the chips up from under and around the lathe and got them out of the shop. Then I went the store and bought two of the flourescent bulbs that I have always I would buy when I was forced to buy by my rich uncle.
Even the wire grates wouldn't stop chips form getting into the hoods.
Re: shop lights
Re: shop lights
Don Lennon
I have had same thing happen to me with little flames of chips falling into the ones on the floor beneath me.
Cat bowl of water was first thing i reached for. Since then I have made a strong habit of blowing off/out the lamps from top and bottom every so often and make sure the chips beneath them are also not so piled up
Re: shop lights
Dick Hines
Re: shop lights
Dick Hines
I don't like waiting for the florescent bulbs to come up to full power but they can be on for hours and I still can put my hand on the and they are not hot enough to burn me.
Re: shop lights
Joe Fleming
Re: shop lights
Joe Fleming
I use these too for all of my garage and shop fixtures. I have never had one above the lathe get hit, but I have taken a couple out with errant 2 x 4s over my shoulder.
Re: shop lights
Re: shop lights
I also changed to the CFL's for the same reason. I just don't like the idea of something smoking in my lights. It does take a little getting used to when turning on the lights on the lathe because they do need to warm up. It only takes about a minute so I turn them on first thing and buy the time I grab my tools or mount the wood they are warm and ready to go.
If you don't like the color of the light they do come in different colors. I buy the daylight bulbs.
Re: shop lights
Re: shop lights
Ed Larson
I just switched to daylight CFL's (100 watt equivalent) for my Moffett lights. No smoke, no heat and better lighting than with 100 watt incandescent. Also my overhead florescence's are out of the line of fire.
Re: shop lights
Re: shop lights
darrin hill
so the consensus is just get those plastic tubes to cover the lights and tape the ends to the plastic tubes so they don't separate?
d
Re: shop lights
Seems to be.
Don Orr
It's what I use also. Won't keep the tubes from breaking but contains the shards and mess. I've been lucky and have never hit one over the lathe-yet.
Re: shop lights
Chuck Jones - West TN
Mine come on almost immediately
I must be using the wrong kind of bulbs. There is a only a negligible delay in mine. Maybe 2-3 seconds. I have the daylight T5's overhead (about 11' above floor) and Lowes/HD/Wal-Mart screw ins in some task lights. All of them come on almost immediately.
Re: shop lights
Re: shop lights
Don Evans
Lowe's carries the clear tubes for the bulbs to go in that protect them or you from the tubes glass shower. They have 4 ft and 8 ft lengths. I think they are little on the high side but depends on how many you need, price $4.00 and $8.00 each, there is also end caps with them.
Just put these on the tube and reinstall the tube in fixture, good to go.
At the local Lowes they are with the light bulbs, in that area.
Don
Re: shop lights
Re: Mine come on almost immediately
Don Evans
Chuck, they come on instantly but they are not full power for about a minute. I just turn mine on (all of them) when I go into the shop. I didn't change them for any saving of energy, I changed to the spirals in task lights to get away from the heat other lights, like Moffetts generate.
I just purchase my first (GREEN) 2' Florescent tubes (2) in the fixture in the closet and they flickered so badly that I changed them back to the old bulbs.
Don't know what going to do when the GREEN labels are only thing available.
Don
