Woven Hollow Vessels?
charlie belden
While fleshing out my notes from the demonstrations I attended at the San Jose Symposium, specifially my notes from the Alaine Milland demo on bending wood, it occured to me that, after sawing a thin walled vessel vertically to create vertical strips to bend later, you could, rather than merely bend the strips, use them to weave between - and make an actual woven vessel. And if the wood to weave between the vertical "staves" (I was married to a weaver and still don't know which is the "waft" and which is the "weave") were dyed first, another level of interest could be incorporated in the piece.
Instead of the illusion of a woven piece, why not do an ACTUAL woven piece? A little turning, a little basket weaving - a potentially interesting piece?
I'm sure this "new idea" isn't new at all and has been done before since there's very little new under the sun - most "creativity" actually being merely synthesis - combining existing things and ideas in new ways. Anyone seen this idea used. If so, got a link to an example or two?
Just throwing out an idea Comments, suggestions, questions, etc. welcomed.
Re: Woven Hollow Vessels?
Steven Antonucci
Isn't that just a basket?
Steven Antonucci
Thin woven strips... basketweaving?
I didn't know that Alain's pieces were bent? I assumed that he turned the profile and cut away the rest. Go figure.
Steve
I haven't seen it done exactly that way yet but Bobbie Clemons and his wife Dorris used to do vessels that had a wooden bottom and top and Doris wove the basket part in the middle. they were very striking.
Re: Isn't that just a basket?
charlie belden
As is often the case, I frequently overcomplicate things. Like you, I ASSUMED his pieces were TURNED somehow, with some tricky carving to do once off the lathe.
When he showed how he ACTUALLY makes his pieces I was amazed out how much less complicated his process is. That is not to say, in anyway, that the pieces he does would be EASY to do using his process. On the contrary, there's a lot of skilled work in his pieces. And it's how he applies the process he came up with to create aesthetically pleasing pieces that, coincidentally, have a high "How The Hell Was That DONE!?" factor - that make his pieces so fascinating, beautiful and a bit mystifying.
I still see some interesting "basket weaving" possibilities that could use part of the Millaind technique. That's going on my One Of These Days I'm Gonna Have To Try list.
As for the question "Why not just basket weave - a wven basket?", a similar question could be asked regarding almost everything we turn, expcept for maybe spindle work - a wooden cowboy hat, a vase that will never hold a flower in water, a plate or platter that no one will ever eat off, a goblet no one will drink from . . . The usual answer to all those questions is Because I Can.
Steven Antonucci
A little different perspective
Steven Antonucci
I don't know that it's the same thing?
I am not questioning the "why weave" part of it, but why turn it and then carve it away just to weave it... Seems like a Rube Goldberg solution to an otherwise "solved problem".
I suppose that I could find a bunch of odd ways to make something simple in the name of art, and have the "process become the piece". Performance art? I don't know...
Perhaps I could make a basket and tell people I turned it? The "performance art" part of it would be the deception of perception...
Piece or process...hmmm?
Re: A little different perspective
charlie belden
I can see several possibilities for this process that may not be able to be done with conventional basket weaving.
With this "bent staves" method, the vertical parts of the weave could be "fixed" in some single axis profile, the woven components then loosely laced in and out of them. OR, the staves could be bent and then fixed in a shape that does NOT have single axis symetry - undulating surfaces up and down the piece.
bernard feinerman
Jim Silva has been doing a version of Nantucket baskets at www.nantucket-turnings.com that combine weaving with woodturning for a number of years. Here is a link to a thread on Sawmill creek that provides an explanation of his work
http://www.sawmillcreek.org/showthread.php?184094-Nantucket-turnings&p=1900825&highlight=#post1900825
Is this the type of weaving you are looking for or ????
Bernie
Mike from St. Clair Shores
I made a bunch of these boxes 4 or 5 years ago. They were time consuming. The form, bottoms and tops were all turned. About 4" x 3".
Steven Antonucci
I like that
Me too!!
JSilva
Mike,
Those baskets you show are similar to Nantucket baskets which have hardwood bases and are woven over a mould to give the basket it's shape. The turned rims are often referred to as "cheater" rims as they don't require lashing to attach them to the top of the basket. Lids, handles, etc can be added also. The Nantucket weave is finer and tighter than those you show but the principal is the same. Good job on those baskets you've shown photos of btw.
I've been using my turned bowls, vases, vessels as weaving structures for a number of years to incorporate the Nantucket weave onto the turnings. I use hand shaped cane or hardwood ribs and cane weaver (Generally 1.50 - 1.75mm). It's a fair bit of work but I like the results.
Jim
