TPI adaptors - Big to Little
David C. Lykins
I normally post on the generic "Messages" side of WC, however since this is turning/lathe related I thought I'd post over here. Long story short, I have access to an Atlas Metal Lathe, Model 3996 (my tools are currently in storage) and I was thinking of sticking my "Barracuda2" that has 1"x8TPI on the Atlas to turn some things. I believe the Atlas has an 1 1/4"x8 TPI chuck.
So......I was wondering if anyone makes a TPI adapter that down sizes the fitting so I could safely use the Barracuda chuck on the Atlas lathe. Also, I have a MT#2 pen turning mandrel, is it OK to chuck the mandrel into the metal chuck on the Atlas lathe to turn pens and such. Gee....I hope the Atlas has enough power to turn pens and stuff...LOL.
Any information is GREATLY appreciated.
Re: TPI adaptors - Big to Little
Harry in Beautiful Downtown Kulpsville
Penn State Industries offers a bunch of these at reasonable prices. I hsve one to adapt a small Nova 1X8 thread chuck to my Nova DVR. works fine.
Leo Cuellar
Re: TPI adaptors - Big to Little *LINK*
Leo Cuellar
And yet another choice for you! :D
Craft Supplies USA
Dick Coers
Isn't there a diameter on the outside of the threaded adapter on the Baracuda that you could grab with your metal lathe chuck? Or cut the head off a 1" 8 bolt and grab that in the metal lathe chuck.Also, you could take the mandrel bar out of the morse taper adapter and grab that with the metal lathe chuck.
The atlas lathe may have a larger morse taper possiby #3. You can buy morse taper adaptors from places like Grizzly and Enco.
Jim DeLaney, Austintown, Ohio
Re: One site
A couple years ago, I bought a 1 X10 to 1 X 8 adapter from those folks, and it was spot on perfect. Yeah, they're pricey, but the results are worth it.
Having said that... If this is an Atlas metal lathe it has thread cutting capabilities. Why not get a big chunk of iron - or maybe aluminum - and make your own adapter. Could be a fun (and learning) experience.
Re: One site
I just had Vic from Bestwoodtools make me a custom adaptor from my drawings. It was also perfect.
THANKS!- TPI adaptors - Big to Little
David C. Lykins
Thanks so much for your input, I figured you guys/gals would know how to solve my problem and where to get an adapter. Looks like Penn State Industries has the BEST BANG FOR THE BUCK at $19.95.
Although like someone indicated, I guess I could ACTUALLY READ the Atlas manual and figure out how to turn one........ I can do basic stuff on the metal lathe, but never tried cutting threads yet, let alone "inside" threads.
Thanks again!
David
Steve Kubien
Penn State
Steve Kubien
I do the exact same thing.
Re: THANKS!- TPI adaptors - Big to Little
Jim Breeden
David: I have 2 TPI's from Craft Supplies, both 1x8 to 1-1/4, and am happy with both. Super heavy duty! Stainless steel. Had to bore a hole in both to accept a grup screw, for reverse turning. Don't have any experience with PennState, except for some lousy turning tools - never again.
Don Evans
Don't know if you'll see this or not but turning threads may create it's own problems. This lathe and Logan's (like I have) require a certain set of gears be installed on the left end of the lathe for EACH tpi you want to cut. Then again you could have what is called a gear box on your particular lathe with multiple gears inside it and levers on it to move to set up the right combination of gears for some tpi's.
The big problem is that 8 tpi which is common in woodturning lathes is NOT a standard, the closes standard being 7 tpi. Sooo, you probably don't have the right gears to do 8 tpi and it may be a problem to get them. I know that Boston Gear probably has them or will make them but then the problem becomes what they cost.
If you don't have a gear box and have to change gears on left side then you gotta figure out if you can do 8 tpi with the combination of gears you have, go to the manual.
Turning threads, so I've been told isn't all that hard, BUT, reading how to do it then putting that into practice is another story.
After reading it a couple of times I gave up and took what I needed done to the local machine shop and had it back the next day. I usually don't give up that easy but as I get older I realize there are some things I really don't need to know, the time taken up trying to learn it is more valuable to me. When I was younger and much less money then I learned how to do it out of necessity.
I call this "buying back time".
Don
David C. Lykins
Hi Don, thanks for the information. The particular Atlas Metal Lathe I'm using has the gear box capable of setting the TPI for thread cutting. But I also assumed that NEITHER of the TPIs I needed would be standard thread cutting for the metal lathe. I haven't really dug into the manual to totally figure out all the thread cutting settings, however for $25 (including shipping) I wimped out and purchased a 1-1/2"x8 TPI to 1"x8 TPI from Penn State Industries to accommodate the threads on the head stock of the lathe.
I'll try to re-post once I get the adapter to let everyone how it works. It appeared to be machined from stainless steel and machined quite well, however the specs' did not state what material it was machined from.
Thanks again for the information.
David
