I know that "if you have to ask, the answer is probably NO!"...
However, I run through a lot of those little propane tanks on my plumbers torch and I was wondering if there was some obvious reason that I wouldn't want to buy a tank for a barbeque grill instead and just run the proper lines? Is it as simple as having the right hose?
Re: Wondering if my brain is trying to kill me? *LINK*
Steve I looked into it for a while to help me with my metal work and silver soldering. It was too expensive at the time but maybe I should look again since I have a spare tank laying around. I looked at RioGrande.com see the link below.
I've seen plumbers use the large grill tank for their torches so you should be able to find a hose that has the right fittings. Also you might try whats called Lamp work ( hot glass work with a torch) they use both size bottles.
(I'm assuming you are thinking about connecting a torch of some sort and not just refilling the small bottles.)
My wife is an avid and long time lampworker. We have hooked her torches up about any way you can imagine: small bottles; 20lb BBQ type bottles; and now a permanent line from the same 500 gallon propane tank that supplies her shop furnace.
She uses oxygenated propane and we have been down a similar path with the oxygen, including two oxygen collectors which she is now using.
Most everything we have used in the way of connectors and hoses came from a local welding supply store. Nothing exotic about it. As others said some of the connectors can be found in a good hardware or plumbing store.
I have been debating adding an oxygen stream for certain applciations and I never though of a welding store. The hard problems have all been solved if you know where to look for answers.
Steve - You may want to try MAPP gas as an initial upgrade. You get a singnificantly hotter flame and you don't have issues with oxygen. The welding guys can help you, but also MAPP cylinders and torches are a standard at HD.
I've used MAPP before, and I agree that it has its benefits, but it is way more expensive than the standard blue propane tanks. If buying it in bulk is viable, I will consider it, but I want a "grill-sized" cylinder because I assume that storing them requires no more thought than a standard barbeque. I'd be leery about having a bigger tank than that next to the house.
