Elm burl bowl/platter
Roger in MO
Roger in MO
Some time back I asked for and received suggestions for an elm burl/canker that I was turning. I deepened the bowl slightly, removed some of the bark, filled some voids with epoxy/coffee grounds, added CA to so soft spots.
Detail on the bottom side was added. ( the void does extend through the bottom)
I'm fairly well pleased with the result but its too thick and heavy. I may try to rechuck it and remove some of the bottom. Its 11" dia and 2 1/4 thick. It has changed shape to some extent. Rechucking will be a challenge.
Comments appreciated. Roger in MO
Re: Elm burl bowl/platter
darrin hill
were u drying it in the oven?
Roger in MO
Roger in MO
When I started about a month ago it was fresh cut. The band saw blade loaded up with gunk. Since that time it has been on shop tables or on on the lath. No other drying methods used.
