6 inch X 49 inch sander
bill Crommett
I am not as sharp as I once was, and that causes many problems. I have a 6 inch sander that I used to use to flatten segment rings until I got a Performax.
After a couple of years of neglect I decided to put a new belt on it, but I can,t remember which way the belt migrates. Is it to the high side of the rollers or to the low side ? I wore out both thumbs before giving up, and now I ask for help.
Re: 6 inch X 49 inch sander
Chuck Jones - West TN
Re: 6 inch X 48 inch sander
To the low side if I understand your question correctly. I guess I'd refer to it as the side that is not as tight. If it's like mine it takes a very, very little movement of the wrench (assuming that's how yours tightens) to start that sucker in the other direction. I just have to keep finessing it a tiny bit at a time until I get it. Then I lock the adjustment bolts down... and then start all over again. :)
I'm assuming the 6 x49 is a typo and it's really 6x 48. If not then I need to hush because it's not like mine.
Re: Stated another way....
Steve Criscenzo
Add tension to the side the belt it is migrating to. It usualy takes very little adjustment o make the belt move. If the belt gets too tight, take some tension off on the side opposite the direction the belt wants to move. Be sure to get the belt reasonably tight before starting adjusting or you are wating your time.
My unit has holes in the adjustment knobs. I use a piece of round bar in these holes to turn the knob. it save my thumbs and allows me to get some tension on the belt.
bill Crommett
Thank you Steve and Chuck. Yes the 49 was overkill by numb fingers.
I thought that I had loosened the tension in exact increments when I took the old belt off so I would not have this problem. It looks like "exact" isn't what it used to be.
