ADVERTISE HERE - FREE TRIAL
OT: Blood Pressure Issue
Stuart Johnson
Let me start off by saying I have been and am continuing going to my doctor. I also have my wife monitoring as if she was trying to catch me cheating or slipping out to play pool instead of mowing the yard.
I elliptical between 1 and 1-1/2 hours 6 days a week keeping my pulse in the 120 -125 range. I then use a Bowflex 1/2 hour varying between 16 exercises. I weigh and record all food and stay between 1200 and 1500 calories daily. I've had a slow but steady weight loss and have been feeling very good and full of energy.
Suddenly last week around dinner time while I was just sitting reading my BP and pulse went from a normal 120/60 55 to 180/90 75 in a matter of a couple hours. It then slowly settled back down higher than normal but in the safe range. This has happened a couple more times. The doctor put me on some BP medicine that has stabilized things and will be doing a bunch of follow up.
I'm not looking to receive medical advice but would like to know if any of you have ever had any similar? If so what was the cause and cure. In my mind when something goes out of whack so fast it means something broke and should be fixed. I've been working too hard to get healthy to settle for drugs being the answer. I will listen to follow doctors advice but I will also try to find alternatives we both can handle.
Re: OT: Blood Pressure Issue
Bill Howatt
No good ideas for you but it does not have to be physical. Something bugging you will do it too.
My wife was had a nurse come to the house to do a blood pressure and questionnaire for an insurance policy. Just before the blood pressure reading was to be taken the phone rang with its long distance ring which usually means it's her son and sometimes with some problem. Her blood pressure went very high but after waiting a few minutes (and determining there was no disaster) it went back down. There is also the well-known "white-coat syndrome" where your pressure is low at home but when you get into the Dr's office it is a lot higher because you are nervous (or severely annoyed for having to wait so long to get in).
If I was running an experiment to measure some phenomonen and my measurements went all over the map the way blood pressure does, I'd be looking for a better way to get my measurements.
Bill
something's not right...
Edgar Davidson
If you're really exercising that much, your body needs a lot more than the 1200 and 1500 daily calories you are taking in. At that rate, you are literally starving yourself. As for the blood pressure variation...it could be perfectly normal, or perhaps not.
Rob Wallace
Rob Wallace
I hope you can get this straightened out and the cause confirmed.....
Similar things happen to me when I watch Fox News (fortunately, I do this very rarely)..... ;)
Don't underestimate life stresses as a possible cause......
I just went through a brief bout with "mild" angina, and after all the blood work, EKGs, and cardiac stress tests I was given a good bill of health (although I should lose a few pounds...). Even my cholesterol was down. The cardiologist attributed the angina to "stress".....since nothing measurable could be confirmed.
.... I personally think that I just don't spend nearly enough time woodturning.....!!
Rob
I applaud you seeing a doctor. I applaud your exercise regimen. Your diet is not sustaining your exercise regimen.
Has your doctor checked your electrolyte levels? Given you a blood test in addition to the other tests? I find that if I don't eat the correct balance of things, my blood pressure might go up.
Chuck Jones - West TN
I smile at this reply...
I haven't watched any news program or scarcely anything else on TV since I retired in 1999. If I want to know what's going on I read it on the internet or in magazines where I can scroll through, or flip pages faster than a speeding bullet.
Life is much better now. :)
Stuart Johnson
Thanks all for the input both here and the emails. Everything is stable right now with the addition of the BP medication. Friday we will be doing the full blood work and hopefully going over my daily calorie log.
I'm not concerned about my caloric intake at this point. I'm not losing 5 or 6 pounds a week but a nice 1-1/2 to 3 pounds. FYI, this is a quote from WEBMD:
Traditional weight loss methods include low-calorie diets that allow between 800 to 1,500 calories a day and encourage regular exercise
I am trying to be certain to eat fairly balanced meals so we'll see what the dr. says. I guess if I have to add beer and nachos I'll just have to suck it up and do it.
bill Crommett
It used to be that salt was the major culprit, and there are hundreds of low sodium products in the grocery stores now. This has not been a problem for me because my BP runs in the neighborhood of 110/65, but after exertion it may shoot up to 140 for a few minutes. Google up sodium influence on the kidneys.
Harry Robinette
Harry Robinette
My BP is crazy Doctor's term,I fluctuate constantly but they tell me I'm ok. I have 3 stints in my artery's
and the Doc says that I'm just someone that everything causes my BP to go up and down. I have to check my BP 3 times a day when I check my sugar.My Golden years have turned to Lead.
Jorge
Stu,
I have high blood pressure too, I don't count calories intake, I don't eat any meat and my rural life means lots of physical work, I don't take any meds.
I get this really high BP moments for no reason at all, the one thing that has helped me is to curb my fluids intake, don't drink unless you are thirty and then drink sparingly.
