This is the 1st time I have made a bowl like this and I am still working on it. It's 3 inches tall by 5 in dia. wide. The hole in the top is 2 inches. It’s made out of white Oak. It's not finished ( just sanded, no finish) and I need an opinion. The top is an angle with a slight curve. Would it look better with a flatter angle than a curved angle?
It is very nice. Since you asked I'll make a couple of suggestions. I like the top half but what I would do is make the bottom a little smaller and move the wide point up a little. It's just a little to low and divides the vessel into 2 parts. Lift the high point up a little and your eye would flow from the bottom up a little better. Personally I don't like straight lines very often. I prefer a slight curve either convex or concave on most surfaces.
Make yourself a Fibonacci caliper for setting the place where you start the top curve. It will give you close to a 3/8, 5/8 proportion. You can use the caliper to set the diameters as well. If you research Fibonacci, you can then apply numbers to pleasing proportion. Here's a link to one guys pattern.
Yes I did ask for a opinion. I can make the bottom foot and thin ( make smaller) the bottom of the bowl, but I do not think I can raise the mid line highter because the bowl has already been turned inside. But I will try. Next time I will adjust the lines.
Dan
PS thank you all for your remarks. I will post the final pic soon.
It's a beautiful piece of wood. You can't always please Fibonacci, or Fiberme, or whoever. Consider the good advice you get here and use what suits you. Move on to the next one. There's plenty of wood available.
Some of my work that my family treasures most was made before I had a clue about good form. Come to think of it, not sure I do now.
