Band saw blade cleaner
Roger-in-Mo
I recently cut a large Chineese elm (small leaves and millions of very viable seeds annually), have split the log sections, coated the end grain and am ready to start cutting the "rounds"
After the first cut the blade and guide wheels had picked up gunk that is difficult to remove. Simple green will soften it but removal still requires scraping.
Is there a better material to clean the blade?
Is there a material to prevent this accumulation in the future?
Roger
Re: Band saw blade cleaner
This is a continuing problem with .....
JamieDonaldson
..roller guides that run against the bandsaw blades, and I fight it with my MiniMax saw every time I cut sappy wood. I would love to have back the Coolblocks that were on my old Delta, but have never been able to find a cure that will eliminate the problem. I scrape the compressed sap off the sides of the blade with a screwdriver, but cleaning of the rollers must be done with the lathe shut off. I have tried treating and cleaning the rollers with PAM, WD 40, and several other concoctions without any lasting success.
Re: This is a continuing problem with .....
I have the same problems. My saw came with the rollers and I would love to have the cool blocks back but haven't found an original block set up for my saw.
Like Jamie I use a freshly sharpened flat blade screwdriver to scrape the gunk off the blade while it's running.
To clean the rollers I push against the blade with a scrap of wood. I want to flex it just enough to make the two outside rollers run. I crank the guide arm down so there isn't very much blade exposed. My hands are well out of the way. While the rollers are running I hold the screwdriver against them and clean them. Then I switch sides so the other rollers a running and do the same thing.
I use the same technique for the bottom rollers but have to take more care because I have to hold the screwdriver up closer.
I'm open to anything else that works. I don't feel this is dangerous if done gently and correctly. However I sure would like to find a better way.
Pitch Rx
Doc Green
I've used this - Pitch Rx - to clean bandsaw blades, circular blades, and turning tools, and it does a fine job. Works best if you remove the blade and spray it with the stuff and let it sit for a while. The pitch, rosin, etc., will then come off with light brushing. It's also claimed to be good for cleaning diamond stones, but I haven't tried that yet.
I bought mine at Woodcraft but other suppliers have it. Do the Google.
It is far better than simple green or plain mineral spirits. Tad expensive, but a bottle will last a long time, especially if you swear off trying to turn sappy pine, the way I did. ~Doc
Chuck Jones - West TN
Maybe Dawn dish washing detergent...
I had not thought about it until just now, but on my Wood-Mizer band saw mill I've always used water with a small amount of Dawn dish washing detergent (Wood-Mizer's recommendation). Not quite the same situation because the mill has a five gallon tank with a continuous drip on the band. But it does a heck of a job. The only real problem I can remember in the twelve years I've been using it is some very sappy pine.
I asked them if it was important to use Dawn brand. They said yes, but they didn't know why and since it works they aren't inclined to research it. I mix about 8 ounces with the five gallons of water.
Hhmmm, now if I can just come up with a good way to continuously drip this solution on the shop band saw blade. Sounds a little messy.
John Scheideman
Jamie and John-
I have a Minimax MM16 bandsaw and Minimax does make cool blocks that you can get for it. I got a set but haven't put them on yet. If you are looking for some I would call them and ask.
John
BarbS
This works for me
BarbS
I triple-fold a piece of 120 grit sandpaper and hold it to the side of the running blade from behind, just up to the teeth but not on them. A bit of thinner on the sandpaper can clean up any leftover grit. I clean the roller guides separately, with the saw off. Then spray the blade lightly with Pam. Many green woods require cleaning the blade more than once during use, but the sandpaper keeps the gunk off pretty well, if used very lightly.
Re: Maybe Dawn dish washing detergent...
Chuck Mark StLeger recommends Dawn as a lubricant for the wood when Hand chasing threads. I tried it and it didn't seem any better than brushing on wax. Maybe it was the wood I was using.
I wonder if rubbing it on the bearings and blade before start up would help.
Steven Antonucci
If you have to do this
steven antonucci
why not make a little wooden jig handle to attach the paper to? A simple square cutoff that you stick PSA paper to would move your hand away from the blade and it could sit flat on the table
I use a cabinet scraper to get the embedded sawdust out of the tires, but only with the saw unplugged and spun by hand...
Steve
I'm with Doc
Mike Gibson
on this one, l won a bottle of Pitch Rx at a club meeting and l am impressed with the results. Michael
Ceramic Guides?
Bill Gasper
My Laguna BS has ceramic guides and I haven't noticed any build up. Recently, I have cut quite a bit of chinese elm without problems.
Bill
Re: Ceramic Guides?
steve worcester
I have the ceramics too, but generally the guides are positioned far enough away, build up doesn't affect them. If you have a sharp and properly tensioned blade, you don't need the side guides that much.
The Laguna ceramic guides are a.....
JamieDonaldson
..high tech version of the coolblock design and work very well, but I haven't found any way to adapt these guides to my Minimax S45N, and the ceramic replacements cost over $200 a set. :b
Re: Band saw blade cleaner-Thanks
Roger-in-MO
Ask and ye shall receive, the good Book says and that certainly is true with WC. I softened the blade build-up and used a sharp screwdriver as suggested. Worked fairly well. Will try John's method on the side wheels on another day.
The stump was about 30" dia. and about as long with a huge burl on one side. I blanked several 4"x13-14"x 30" slabs from the stump and have several more to cut. I have not tackled the burl except to shave one side. It looks promising. I took some photos but am too tired to post tonight. It may be a few days but I will post a gloat if the burl turns out like I think it will. Doc, I'll be looking for that cleaner too.
Thanks for all the suggestions. I normally don't bandsaw wood as wet as this is.
Roger
BarbS
Re: If you have to do this
BarbS
Could, yeah. Never had a problem with it, but it would be safer.
Peter Hyde
Take the blade off and use a stiff brush and oven cleaner. You can also clean up table saw blades the same way. On the roller guides try to keep it off the seals.
Lacquer thinners will also work.
I know I can clean the blade and rollers but have no desire to dissassemble the machine and remove the blade every time I cut green wood. :) That's why I developed the method I use, which I don't think is the ideal way to do.
I tried waxing the blade and rollers. Helped for about the first 2 pieces. Same was true with WD-40. Helped a little but when you cut up a bunch of blanks it didn't seem to do the trick. Maybe an application after every blank but then I probably won't stop to do that.
I haven't tried PAM yet. Not real excited about spraying cooking spray all over my saw.
Peter Hyde
Yeah John I hear you it's a pain :) I use a stick of wax I bought from somewhere that I wax the blade with and I have metal blocks for guides (Old General 390) so I don't have a problem usually. When it comes to the point it really needs cleaning it only takes 5 minutes to slacken off the blade and remove it. I used the oven cleaner with the blade installed. Ran a big piece of formica past the blade to protect the table and raised the guides to access as much of the blade as possible. Brushed on the cleaner, let it sit and then wiped off all the gook with a paper towel. Moved the blade and did the next section. Took longer than removing the blade :) Anyway I now keep 2 blades on the go and when the build up gets bad swop them out, that way there's always a clean blade ready to go.
steve worcester
Trust me, WD40 makes a bigger mess that Pam will, and the cuts will smell like dinner.
