Boy is it hard to get these right. I think I have flat areas in the neck of the tall one and didn't get the base nearly as nice as the first one. The upper part of the neck and the Head are better but still not what I'm after. I thought I was really careful with the beads on the tall one but apparently I sanded just a little to much and got the top of the beads a little flat.
Of course I'm being picky but that's how you learn. I'm pretty happy with both of them and having fun doing them. One of our vice presidents is afro American and a fabulous painter. He and I share ideas. He likes these and wants to sketch up his interpretation. I told him I would consider making one from his drawing. Since these do have an African basis on the design it will be interesting to see his take on this.
These are great. A wonderful series. Lots of opportunities to play with form within tight bounds. Tiny changes make a big difference in final appearance.
Have you considered not beading all the way to the top? I can see a form with the top 3 or 4 beads not cut right under the "head".
Keep 'em coming. I know you're having fun! I just hope you have plenty more clarinet bells to play with! ...Gary
While i can see the flat areas in the curve of the neck, the overall effect is well expressed and I wouldn't be too critical. When I attempt a design-build of a new form (for me) I can just expect to "miss" a bit on the first two. Third time is the charm...and I'm looking forward to see the next one.
I agree with your self critique, but without it I probably would have just thought these are two excellent pieces. I have enjoyed seeing their development. For what it's worth, I like the shape of the top piece on the tall one better than the short one; and the foot better on the short one.
This is my mini beading tool that I made for the Genie bottles. I made it from a screwdriver but it needs improvement. I'm going to start a thread on beading tools to see if we can improve them.
On this one I simply filed a groove using a jewelers rat tail file. I think when I have time this weekend I'm going to try and file it so it has a much sharper angle from the bottom and possibly put a negative rake on the top to make it an even sharper angle. It might not hold an edge long but should cut like a skew on it's side.
I'm having trouble with tearout on the very crest of the beads. I've always had this problem with beading tools. I start with the tool below center and the push the handle down do raise the cutter through the work. That seems to cut the sides very clean but I can easily get chip out on the crest of the bead because at that point it's just scraping. I would love to come up with a way to make it a shear scrape or a cut.
One thing I thought of which I will try today is to use it as a bevel rubbing tool. If I grind the bottom so it has a bevel it might work. However I'm worried that the tips would be too weak and possible break off on harder woods. I could make them wider but then that leaves a wider space between the beads.
Anyone have any suggestions. I guess I probably should have put something in here for size comparison. This is less than 1/8" bead, maybe 3/32 or so.
Try the other way with the cutter above center and the handle down. Bring the handle up and as the cutter enters the tool do a little, ever so slightly rocking back and forth and gently keep doing this until the bead is formed and stop once the flat disappears. That's how I use the D-Way beading tools.
