Chainsaw safety
Chainsaw safety
Chainsaw safety
Starry Chan
I have chainsaw with a 18" bar but I need to split a log 24" long. What is the safest way to do this?
Re: Chainsaw safety
Re: Chainsaw safety
robo hippy
You can actually use wedges and a sledge hammer if you want, and are not very picky about a flat surface. Otherwise, get the log to comfortable working height. I get mine up on an end grain log about 20 inches high. Wedge it up right so it will not rock while you are cutting. I will mark plumb lines on each end, then you can snap a chalk line if you want, or eyeball a straight line. Start the cut on the far end, saw down till the blade is about 45 degrees, then continue down the log. You can then roll it over and cut from the other side.
If you are making bowls from it, I would cut it to bowl size lengths, then rip it down the middle. If you want to make boards from it, splitting it might be easier. With a blade that will not go all the way down the length, the sawn surfaces will not be any smoother than the split surfaces. Only difference would be that some times wood grain rotates or spirals through the tree, so split log section might have twist to it.
robo hippy
Re: Chainsaw safety
Re: Chainsaw safety
Barbara Gill
Can you not access the log from both ends?
Re: Chainsaw safety
Re: Chainsaw safety
R Payne
The safest way for you is to pay someone else to do the work for you.
You could get a bigger saw (or check your manual to see if what you have will handle a bar big enough to get it in one pass).
You could do it in 2 passes if you block/wedge the log.
You could split with a few wedges and maul (or sledge).
There is the old school way of a saw pit and 2 man saw (if there is someone else to help).
There are many ways to skin this cat.
ron
Re: Chainsaw safety
Re: Chainsaw safety
Dick Coers
Lots of ways, but maybe another idea. Saw 18" deep, and split the rest of the way, or snap a chalk line and angle the saw, ripping down the line.
Re: Chainsaw safety
Re: Chainsaw safety
Doc Green
Starry, here's my suggestion:
Place boards, sticks, or whatever on the ground and place the log on top of these. The sticks will help to keep your chain out of the dirt. The pith should be horizontal.
During the cut, the log will be pulled toward you. You must prevent this. One way is to drive two short stakes in the ground next to the end of the log closest to you. Also, chock the log so that it cannot roll side to side.
Start the cut on the far end of the log. To prevent the chain from pulling the log up and toward you, have the bar/chain very nearly parallel to the surface as you begin the cut. Then, once you've entered the cut an inch or so, gradually raise the body of the saw so the bar will angle downward, eventually ending up at about a 45 degree angle to the log. The required angle will depend on the diameter of the log.
Once you have the cut established, simply continue it toward you until the cut is complete. Watch for any tendency for the log to lift. Once you get part way down the log, you can lower the body of the saw so that the bar/chain is more nearly parallel to the pith.
If the log is more than about 12" in diameter, you may have to make a cut on one side, then roll it over and make the final cut from the other side.
Email me if you are not clear on this. Be careful. ~Doc
Re: Chainsaw safety
Walt Bennett
Re: Chainsaw safety
Walt Bennett
Log is 24" long or 24" wide? If wide, I stand them on end and use the two cut method (not all at once, but first part way down one side, then catch up and some more on the other, etc.). Once over half way, flip it over, mark where needed and finish. Once you've done it a few times you'll be able to make a fairly flat surface.
Re: Chainsaw safety
Chuck Jones - West TN
a big Plus 1 for Doc's method
Doc Green's method is written well enough it could be called a tutorial. Only thing that might be added is "stop occasionally and clean the long shavings away". There will be lots of them.
Re: Chainsaw safety
Re: a big Plus 1 for Doc's method
Jorge
Good advice above,
I will just ad: start with a straight edge and a marker choose the best symmetry for the largest bowl on one end, mark it and mark the length of the sides.
I start across the end grain, as soon as there is enough to keep the saw in track, lay it on its side and cut away, most of the time you use only one side, but I mark both, sometimes you wander away fron the line, then flip the billet and have at it following the line.
I get very clean cuts, just a little scrubbing with a hand plane and the blank is good to receive a glue block or faceplate.
Re: Chainsaw safety
Phil Stivers
Re: Chainsaw safety
Phil Stivers
I've found the best solution is to call a friend with a bigger chainsaw :-)
Re: Chainsaw safety
Dick Hines
Re: Chainsaw safety
dick hines
I see a couple of people have said to satre on the end of the log. You should cut the log with the side grain and not the end grain. Side grain will give you a lot of shavings and will cut easier. End grain will work you and your saw to excess.
Re: Chainsaw safety
Walt Bennett
Re: Chainsaw safety
Walt Bennett
That's only if you try cutting straight down from an end. I end up at about a 45 degree angle. Also use a skip tooth chain on the saw I use for this.
