McNaughton Center Saver Knives
Harry in Beautiful Downtown Kulpsville
I need some help. I have the standard size McNaughton Center Saver. It has four knives: straight, large curve, medium curve and small curve. I believe the large curved blade is too big to use with bowls, at least on my lathe.
I have determined that the medium blade will cut a 10 inch diameter circle and the small blade about an ex-inch diameter circle. I got this information by measuring each of the blades. I have not been able to verify these values in any of the catalogs or on the McNaughton website.
What I'm interested in is the curves created by the Mini-Center Saver knives. If anyone out there on this vast forum can provide this information, I would be much appreciative.
Harry
Re: McNaughton Center Saver Knives
The small knife cuts a 6 inch circle. Sorry about the mistake, at my age brain freeze is not uncommon! :)
Carole Valentine
A bowl that I cored last night with the tight curve of the small blade was 7" in diameter. It was cut all the way through...not most of the way and then broken out. I could have gotten a little more diameter from that blade if need be. Probably not much help to you, but I have a big coring session coming this weekend and I will try to take note of which blades I use to get what diameter and depth bowl.
Dale Bonertz
Harry,
I just put my set on my circle chart which only goes to 16" diameter. Keep in mind that the beauty of the McNaughton is the flexibility of the system. Just because a tool is bent on a certain diameter does not mean it can only be used at that. Depth of bowl and shape play a big role.
Here goes:
Mini set - 6" diameter
11" diameter
18" to 20" diameter
Standard - 7" diameter
11" diameter
18" to 20" diameter
Jumbo - 13" diameter
18' to 20" diameter
They are made in family as sizes go. When I say 18 to 20 again my chart only goes to 16 so I guessed by eye on the chart what they are.
Hope that helps.
Dale
Thanks folks. I'm surprised that the mini cutter are not significantly smaller than the standard size.
Carole, I wish you lived closer. I'd come by and get a first hand look at how you core.
Dale, I think we both measured the same way. I used one of those plastic disk gizmos (technical term) that is used to layout bowl blanks. I found it difficult to determine an exact size. And yes I know you can fudge the sizes a bit, but basically the tool wants to cut the given circle.
Thanks again, Harry
