Answer to: "Is my compressor toast?"
david
Some of you wanted to know the outcome of my attempt to repair my Sears 5-HP compressor-upright with a 22 gal. tank. Took it to the regional Sears repair service. The complaint was when plugged in, would cough a few times trying to turn over, then the circuit breaker would trip. The evaluation cost me $35, which would have been applied to the cost of the repair. Any repair cost over $100 needs prior authorization. I just got a call that the motor was not repairable, and no replacement parts were available. I left it to them to dispose of. It was a gamble, but at least now I know that it was indeed toast.
Re: Answer to: "Is my compressor toast?"
Lewis Dodd
Wow! Another motor, new or used , would have been worth it to me to keep the tank and compressor.
david
Not that mechanically inclined. Tried to get the plastic cowling/shroud removed with no success. Just three screws!! Imagine how that made me feel. Prefer to concentrate on something where I will have some chance at succeeding :)
Success is
NOT shopping at Sears for power tools. Gone are the days . . .
Bart Leetch
I feel for you. I'm sure you are a much better turner than I am.
I combined a pump,1 hp motor, pressure switch, some small pipe fittings, gauges & pressure control valve with a 50 gallon hot water tank & have a pretty good compressor. Cost the pressure switch & a few pipe fittings. I questioned a plumber/electrician friend & showed him the system he said it was safe & that the burst point for the tank was way higher than I run it to.
Hydrostatic and air ain't the same......
Richard Jones
I'd be REAL careful with that. If those tanks were suitable for air pressure vs. hydrostatic pressure, the air compressor folks would sure be using them.
Back in another life, I used to build sewer and water plants, using miles and miles of ductile iron pipe. The DI pipe folks will tell you not to air test their product over about 7-8 psi, but you can hydrostatic test at 200+.
Be safe.
Rich
