First bowl of 2012
First bowl of 2012
Steve Kubien
First bowl of 2012
Steve Kubien
This is my first bowl of 2012, completed on January 1st but only photographed today. Honey Locust, turned green, measuring 7" x 3½" and one coat of Watco for now. I call these bowls "meditation" bowls. They feel so nice to just roll around in your hands that you can quickly become lost in quiet thought. I felt it was appropriate to turn something like this to start the year.
Comments and critiques are welcome.
Re: First bowl of 2012
Rob Wallace
Rob Wallace
Went to click the "Like" button, but Woodcentral doesn't have this feature!! I'm becoming too 'Facebook acclimated' I guess. - Very nice Steve!
I have three locust pieces drying right now as rough outs - thanks for the nice inspiration for me to finish them after a few more months of "seasoning" time.
Rob
Steven Antonucci
It's a good bowl for sure
steven antonucci
and that's never a bad thing. I like the color of honey locust better than black locust, which is more green/yellow. Where are my peanuts?
Steve
No comments other than well done. Nice shape, good detail, clean looking finish. What else do you want.
adrien
Didn't know a green-turned bowl could look so nice.
Steve Kubien
Ha!
Steve Kubien
I know what you mean Rob. I've become a HUGE fan of Twitter so I #justwanttohashtageverything.
Steve Kubien
Steve Kubien
Thanks Ade, I think. :) I don't do many of them but this honey locust just feels so nice when turned green.
Steve,
GaryG in MD
I think John said it pretty well.
I'll add that I really like the grain patterns in your honey locust.
Did you use one of those pen beaders to get the regular pattern?
Very well done, Gary
That'll do nicely Steve.
Steve Kubien
How-to, LONG
Steve Kubien
Thanks Gary. I've gotten a couple of emails about the beads so here you go...
No pen beader or other beading tool was used. I used a 3/8" detail spindle gouge. I saw a clip of Richard Raffan doing this (somewhere) and he is what I am doing because of that clip...
Start with the handle low and the flute rolled over a 9 o'clock. The flute orientation will not change. Slowly but steadily, raise the handle which in turn, puts the tip into the wood. Again lower the handle and let the tip skate up the left side of the valley you just cut. As the tip gets to the top, don't lose contact but move the tip in a circular fashion until it is lined up with where you want the next valley to be. Raise the handle as the tip continues to move in that circular motion. Thoughout this, keep the flute pointing at 9 o'clock. You are NOT rolling the tool like you would normally do. Keep repeating this until you have a band of beads the width you want.
In one of the emails I received, the author said how he had a problem doing small beads in bowls because of the fuzzies left at the bottom of the cut. My, albeit limited, experience tells me this isn't an issue and I think this is because the tool is constantly cutting. The tip never leaves the wood until you have a band of beads as wide as you want. If you disengage the tool from the cut and decide to add more beads after, you have to get the tip back into the bottom of the left-most valley EXACTLY where you stopped before. If you don't, you get the fuzzies and a raised hair of wood around the entire bowl. I think that is a PITA, especially when you've got a bowl spinning at a few hundred RPM's. I don't like that much excitement.
So far, my experiences with dry, locally reclaimed wood have not been encouraging but in this wet honey locust, I love the results and they were easy to get.
Hope this helps!
Steve Kubien
Re: That'll do nicely Steve.
Steve Kubien
It's REALLY good that you say that Don. :)
Very nice bowl.  Keep them coming!
Thank you, Steve...
GaryG in MD
That's an interesting technique that I had not previously heard about.
I'm going to have to give it a try on some scrap and see if I can master it.
What's the nose angle and shape on your detail gouge? Is it the kind Cindy and Hannes use? ...Gary
Steve Kubien
Re: Thank you, Steve...
Steve Kubien
I'm not sure of the angle as I've never measured it. Just a guess, around 35-40 degrees. Certainly not as pointy as Cindy's vortex tool or Hannes.
got it...  thanks
