There is nothing I
There is nothing I
There is  nothing I
Terry Scott
I pride my self on saying there is nothing I cannot hold on the lathe somehow
There is always a way
This very thin vessel nearly had me stumped when I went to turn of the foot
1/ I couldn't hold in jaws because of the shape
2/ The thing is full of holes and I thought if I wrapped in tape I might pull out bits of the wood when I went to remove the tape
3 /Jamb chuck was out
What to do The inside is full of close sell rubber and the neck is resting on more padding on the shoulder of the chuck
Then a bit of tape and the support of one hand as a cradle .I gently turned off the foot
next is a bit of sanding while still on the lathe as I want a round bottom.
Why didn't I just sand off the spigot I here you say
I ran the risk of crushing the vessel or going through the bottom and this Malle was hard as so I would probably over heated it and I didn't want a dark spot
Next I will be creating man made worm holes all over the vessel
Re: There is nothing I
Chuck Jones - West TN
Your lathe could use a bath!
Don Leydens
Don Leydens
That oughta do it! When I need to tape a piece or to protect it from the wheels on a steady rest, I use blue painters tape:
http://www.uline.com/Product/Detail/S-11664/3M-Masking-Tape/3M-2090-Outdoor-Masking-Tape-3-x-60-yards?pricode=WU133&gadtype=pla&gclid=CLj8vsfa7a0CFUHc4AodGF1-5Q
This would go under the duct tape. It peels right off and doesn't pull the wood up or leave a sticky residue. If they don't have it down there, I could send you a few rolls to try out, just let me know.
Don
Terry I used to use a combination of blue painters tape and nylon strapping tape. The painters tape comes off very clean and doesn't damage the wood but is not very strong. I would cover the important areas with the painters tape and then use the strapping tape to hold it in place. That stuff is tuff, doesn't stretch and holds extremely well. By itself it leaves goo all over everything and will actually pull some fibers out of the wood.
Walt Bennett
Stubbys work better that way
Don Evans
Terry, this is a perfect job for a doughnut rig to capture the piece. As much of this type stuff you do, you should make 2 or 3. Actually you could use the back half of that type capture and have more than one front capture with different sized holes etc.
If you are not familiar with these doughnuts let me know and I'll fill you in, but I'm betting you know about them. Much easier to mount and no guessing if it will hold or not.
Email me if you want but there is probably a "how to make one" on this site somewhere, I'm brain dead at moment, not enough coffee and cannot remember where that stuff is hiding, I think "Articles" maybe.
Don
Great idea!
Mike Stafford
Stretch wrap and cling wrap.....
Mike Stafford
Stretchable packing wrap like what is used to hold cases stacked on a pallet is a wonderful material for doing what you describe.
You can buy rolls of it 4" wide and a couple of hundred feet long. I like to use it when I am hollowing a piece with voids and I am afraid it will fly apart. Just wrap it with overlapping layers of the stretch wrap and it will securely hold the piece together. (At least it will hold the pieces together should the wood decide to fly apart despite your best efforts.) It clings to anything including itself and I could see it being used exactly as you have used that blue duct tape wrapping the piece and extending back to and around the chuck for security.
In a pinch cling wrap that the wife has in the kitchen will do the same thing but it is not as durable.
Tony Reynolds
Re: Stretch wrap and cling wrap.....
Tony Reynolds
Great idea Mike! I never thought of that.
Tony
Thats why I contribute to
Terry Scott
Thats why I contribute to sites like WC
I can always learn something
Mike I have a snarly knarly burl that will benefit from shrink wrap thanks
I use to hold fresh timber that I dont want to dry out.
A few wraps and it can sit for 3 or four months without end checing some does spalt but that doesnt matter as I color most of my work
Cheers
