Osage Orange Bowl
George Taylor
Took a quick picture since SWMBO plans to "gift" it this evening. About six inches if it was perfectly round. First attempt at lacquer & photography is a work in progress.
Comments and critiques are welcomed.
George
Osage Orange Bowl
George Taylor
George
Re: Osage Orange Bowl
Lewis Dodd
Nice! That had to be a large bo-de- arc tree!
very nice, george
Mike Stafford
Nice George! It will continue to develop a rich brown color.
Lower your camera angle just a bit so that you are peering over the rim just enough to see some of the inside shape yet still able to determine the overall exterior shape of the bowl. John or Jamie are better at advising lighting changes. I still don't get the lighting right.
Please make that: Bois d'Arc
Bob Edwards
I can't get the lighting right either but I saw this piece last Thursday and the color is much more dramatic in real life. Feels good in your hand as well.
Nice work George!!
or bowdock in the rural south
as a rank amateur photographer...
Chuck Jones - West TN
I'd guess you used fluorescent light and you need to set the white balance on your camera. That's probably what is making the color look off. I finally figured out how to do it on my camera after, oh, a few years of fumbling with the menu.
Good looking piece and Osage Orange is one of my favorite woods. Like Mike said, it gets better with age.
I grew up calling it Hedge Apple
here's a very crude attempt at some compensation
GaryG in MD
I got rid of the color cast and corrected the histogram a bit...
...Gary
That's also the common name used out here too.....
Re: here's a very crude attempt at some compensati *LINK*
Rob Wallace
Your choice of the background might also be considered - changing the color/reflectivity may help. Perhaps a darker or less reflective background would help reduce problems the camera might have with assessing exposure. The whole image looks washed-out to me..... The wood HAS TO have much better color and contrast than what the camera is recording. I use a matte finish, non-reflective white to black gradient, and the cameras I use tend to sense the exposure OK if the background is not too lightly colored. I also like using mid-grey or light navy blue solid backgrounds in addition to the white-to-black gradient.
You can also use standard art matte board that is used in picture framing (available in many colors) which can provide a uniform color background.
Lots of things to experiment with and settings to adjust to get through the photo learning curve....I'm also still working at it.
Good luck!
Light meters are calibrated to render.....
JamieDonaldson
...an 18% gray average exposure, so a light gray background is very neutral in reflective light readings. A white background is more reflective and thus causes an underexposure rendering unless manually corrected, and black backgrounds suck up light like a black hole, causing an uncorrected overexposure. Many digital cameras can be manually corrected by using a +1 exposure compensation setting with a reflective white background.
Thanks for the critique and comments
George Taylor
I will keep working on the photography; a good friend's son is a photographer so I will be getting some instructions/lessons hopefully soon.
Thanks again
George
