bracelet
bracelet
bracelet
gary clarke
I am looking for different ways to reverse turn a bracelet. Thanks
Re: bracelet
Re: bracelet
Emmett Manley, Lakeland, TN
Don't reverse turn, make the parting cut from one side only. Do this by using a screw chuck or glue chuck that allows room for the parting tool to go all the way through the wood without hitting anything on the headstock.
Remember to keep your parting tool perfectly in line with the lathe rails (ways) to make the critical right angle single cut.
Re: bracelet
Steven Antonucci
What I've done
steven antonucci
Turn between centers with a tenon on either side.
Grip side one. Part about 1" deep
Grip Side two. Complete Parting.
You should have a tube. Insert tube around chuck jaws from inside and marginally tighten. You can wrap the outside with painters tape to secure it to the chuck if you are uncertain.
Cut inside of bracelet cleanly. Sand to finish.
Reverse it to the finished interior, adding tape to the outside of the jaws to keep the inside clear. Finish cutting and sanding side 2.
done.
Steve
Re: bracelet
Re: What I've done
Gary clarke
Thanks
Re: bracelet
Re: bracelet *LINK*
Kevin Stanbary in McHenry, IL
Bob Hamilton does napkin rings like this, could be easily adapted to bracelets...
http://youtu.be/rfrldsntWbA
Re: bracelet
Re: bracelet
gary clarke
That would well for the segmented braclets that I will be doing. Thanks
Re: bracelet
Ken Vaughan
Re: bracelet
Ken Vaughan
Pictures from an older article by Nick Arull (2008)
I think he calls them Bangles
http://www.woodworkersinstitute.com/page.asp?p=594
