Preferred Alcohol soak container for large bowls
Chris Groves
Chris Groves
I have been using the alcohol soak method for bowls up to 11 inch diameter with a 5 gallon paint container that has a rubber gasketed lid. I am looking for a similar container that I can use with bowls up to 18" in diameter.... has anyone found a round container with a good lid that meets this criteria... I want to minimize the amount of DNA I need to use for submerging the rough turned bowl...
Chris in Lexington, MA
Re: Preferred Alcohol soak container for large bowls
D. Hansen
look at "Rubber Maid" type products. They come in so many sizes you should be able to find one that works. Another way is to use a plastic garbage bag just make certain it is one that will hold liquid; that way you only need enough DNA to cover the vessel in question.
Chris Groves
Chris Groves
I was at my favorite local hardware store (O'Connors in Billerica) and once you get larger than 12 inches in diameter most of the containers are rectangular.... an upside down Rubbermaid cake container was the best I saw but it only was good for up to 13" and tapered... I would prefer a plastic container over a poly bag... worried about 2to-3 gallons of wasted DNA if it springs a leak...
D. Hansen
Yeh I hear you. I put a trash bag into a larger container. Put the DNA in it, insert the bowl and pull the bag up around the bowl. That way if it leaks you haven't lost anything and you only need to put in enough DNA to cover the bowl so you don't need to fill the entire container.
Pack sawdust and shavings ...
Doc Green
My method is to place the bowl in a plastic garbage bag, then place the bag in a larger container and pack sawdust and shavings around the bag and bowl so that the plastic is pressed against the bowl, inside and out. Then I add the DNA.
I test the bags to see that they are water-tight first, and then double my odds by using two bags. "Contractor bags" are much thicker and more durable than regular garbage bags.
I can cover an 18" bowl with perhaps a quart of DNA. Have never had a leak.
~Doc
Chris Groves
Re: Pack sawdust and shavings ...
Chris Groves
@Doc... I like that you can get away with only using a small amt of DNA... very clever... I will try this on some green maple and some green cherry that i picked up recently... courtesy of "Irene"
Do you use a twister tie at the top of the bags to seal
Great use of the sawdust and shavings... I can always get some nice sawdust from the base of my Unisaw...
Chris
arthur in LA
I found some large round containers at a restaurant supply, some place in Tx. The top was sold separately. I think mine is about 15" but I know they had larger. Maybe Midwest was in the title. Sorry I can't be just a little more specific and helpful.
Chuck Jones - West TN
Look at a Kingsford Charcoal container *LINK*
I bought one a year or so ago at Wal-Mart for about $15. I'm not positive, but I think I have put an 18" bowl in it. The seals are extremely good. Lid easy on and off. Very sturdy. I've had no leakage and very little evaporation.
Try the link below or search on charcoal storage container.
The Container Store
Steven Antonucci
I also use the garbage bag trick
steven antonucci
I accidentally drove over my 5 Gal bucket with my truck, so I only have less than a Gallon left. Double bag in a plastic tote. Even if you don't get total submersion, the wood wicks the DNA into the pores.
I knot the bags and cap the tote. I then put the tote somewhere I do not intend to drive.
Steve
Dennis in Southern Oregon
Just a bit of caution. Don't get carried away by trying to use too little alcohol. This process works by exchanging alcohol and water between the wood and the pool of alcohol that is in contact with it. At the end of the process, the water/alcohol ratio is the same in the wood as it is outside the wood. Thus for example, if you start with an amount of alcohol that is equal to the amount of water in the wood, you will end up with half as much water in the wood as you started out with (plus and equal amount of alcohol). If you want to remove 90% of the water from the wood, you need to start with ten times as much alcohol as the initial amount of water in the wood. In all this, the "amount of alcohol" refers to the alcohol that is in contact contact with the wood and able to interact with the wood.
Dennis
Chris Groves
Re: Look at a Kingsford Charcoal container
Chris Groves
Thanks Chuck... we have 2 Container Stores not far from where I live... from the picture it looks like it will take a 16-18" diameter bowl.... thanks for the tip...
Chris
Mike Stafford
Mike Stafford
I don't have a picture of the container handy but maybe I can take one later.
I was able to find an industrial detergent container that is 24" in diameter and 15" deep. It has a gasketed lid which snap locks on to seal tightly. Thiis is good so that the alcohol does not evaporate. I can put any bowl or platter blank I care to turn inside and most of the time have a bunch of box blanks inside. All I do is add more DNA as needed and filter the alcohol once or twice a year to get the sludge off the bottom that inevitably collects.
This soup is black in color and when I first take light colored woods out they are discolored but when I return them the light color comes right back since the discoloration only affects the first 1/32" or so.
Tequila
Jorge
Chris,
I am late in this talk but I did experiment with alcohol in the past and bowls submerged in DNA had the same rate of attrition as bowls left out with nothing on them in a quiet spot of the shop, I assume if a bowl is going to crack, it will, alcohol or not,. the drying time is not that much either, bowls roughed in the dead of winter in really cold weather dry in about 3 weeks, they take a couple months in the summer.
The alcohol. is not cheap, so you spend on it and right after the first bowl it turns black or near it and subsequent bowls get stained by it. So I thought it was too expensive method and I just leave my bowls to dry in a quiet spot as said above. For quiet I mean, not near a heat source and away from air moving fast.
Now and then I get nervous about an expensive blank and then I resort to alcohol, I take a shot of tequila...
Chris Groves
Re: Tequila
Chris Groves
Thanks everyone for your comments on containers and the DNA drying method... It is great to get almost instant feedback from this exceptional community.
I hope 2012 brings a good year for you and your families.
Chris
Ric Taylor
Ric Taylor
I use one of the flat plastic storage containers that are designed to slide under a bed. They come in a variety of sizes and you can easily find one up to 24" wide, and they are not very deep so they are perfect for platters without using much alcohol. I put tape around the edge of the lid to keep evaporation at a minimum.
Ric
