Hey nova people.. i got electricity..
darrin hill
i have a nova dvr xp.
Last night i tried to realign the tailstock with the spindle, using a morse taper alignment tool thingy..
however.. when i touched an allen wrench to one of the screws that holds the tailstock to the bed, i saw a tiny, tiny insignificant spark. When i tried touching it again, about every 5th touch would make the tiny spark again..
so i thought maybe some dust was inside making a short... so i took the controller case off and it was full of dust. I blew it out completely... didnt get into the motor.. tried to blow through the holes in the back of the motor, and dust did come out..
but when i touched the allen wrench to the screw again, the sparks were about double in size and would occur every time i touched the wrench to the screw...
so.. is it dust in the motor, should i clean the motor, or what?
darrin
Re: Hey nova people.. i got electricity..
Bad ground?
Jim Sebring
Sounds like a bad/loose ground wire somewhere. Could be a dangerous situation. You better call the support folks in Florida.
Static Electricity?
Doc Green
My first guess is that it's static electricity. Were the conditions right for it ? ... Low humidity in your shop? Dry shavings or a lot of dust on the floor? Were you wearing rubber-soled shoes, or the equivalent? Wool sweater?
I suspect that you were building up a charge on Yourself as you moved around the shop. Then when you touch the wrench to the screw, you discharge yourself to the grounded chassis of the lathe.
If you place your hand on the ways of the lathe then touch the wrench to the screw, you will never get a spark if it's static electricity because you will discharge yourself when you touch your hand to the ways.
Dry dust is an excellent insulator. Oil is an insulator. There is no way that I can imagine that dry dust inside a motor or the controller would cause what you describe?
Try the same thing with another piece of grounded equipment in your shop. Touch the wrench to a metal part of it and see if you get a spark. Dim light makes the sparks easier to see.
Good Luck, ~Doc
Re: Static Electricity?
I suspect Doc is right and you should check for static electricity. You should also make sure the lathe is grounded. Static electricity and electronics are not a goo mix.
And, you should read up on blowing the dust out of the motor cavity. I have an older DVR and IIRC you are supposed to blow it out occasionally. Either check the manual of the web site.
Could be either although I have never noticed a static electricity problem with any of my lathes. I have had a bad ground at my old rental house and would get shocked when standing barefoot on the concrete floor and touching the lathe. It was mild but I new something was wrong. You could measure the current. Don't remember how much it was but I ran a ground wire from the plumbing to the machine and stopped it. That was an old house with metal water pipes. I'm not an expert in this area by a long stretch so hope someone else will tell you how to check and solve it if in fact that is the problem. I read up on proper grounding when I installed my 220 line in my shop but that was 5 years ago and I don't remember many of the details. In fact some days I can barely remember my name. :)
If it's static electricity simply running a wire from the machine to a good ground will solve that quite simply and safely.
Rob Wallace
Wrong thing to ground!!
Rob Wallace
John L. wrote "If it's static electricity simply running a wire from the machine to a good ground will solve that quite simply and safely."
Grounding of the machine should be done anyway (required as part of the electrical code), and it may already be perfectly sufficient through the third conductor of the power cord. It is probably not the lathe that is building up the static charge - it likely is the operator!! If Doc is correct (and I suspect he is), further grounding the lathe will NOT solve the problem of Darrin getting static build up on him! The lathe is already acting as the ground in this case.
Another possible source of generated static might be from the insulating effect of a cushioned floor mat which is commonly (and wisely) used at many operating positions at the lathe. Walking across dry wood chips atop this insulator can possibly generate static build up, especially under dry atmospheric conditions frequently found this time of year in heated houses or shops.
If this situation continues to be annoying, there are grounding bracelets (for wrists or ankles) with wires to connect to a ground known to be "good" that are used in the electronics industry for workers having to deal with static sensitive electronic parts. (I do not suggest using this on one's wrist if the operator will be working at a lathe! I suppose having a tether on one's ankle really isn't too safe either!) If a floor mat is being used, one might be able to spray it with an anti-static product designed for that purpose. Alternatively, you might just have to live with the static if that's identified as the problem...???
Rob
Harry in Beautiful Downtown Kulpsville
I also believe it is static electricity. Think about it, there is nothing electrical in the tailstock. You did mention tailstock, though you probably meeant headstock.
Another solution to the problem is to install a humidifier in your shop. There are many inexpensive models with a tank that you fill about every 8-12 hours of operation. Depending on the size of your shop, one of these should raise the humidity significantly.
Jim Breeden
I also have a DVR, and have not had the spark experience, even where I live, where it rarely gets above 17% humidity here in ABQ. Question - does your DVR need to be realigned occasionally? I check mine often and don't seem to have a problem. :\
its probably not static electricity..
darrin hill
nope.. it's the tailstock.. the one that moves up and down on the late bed.. and is opposite the headstock...
and i really doubt it's dry enough in my area to be static electricity...
today our average humidity is 45%... and thats really low for us..
Dick Hines
dick hines
I know on cold dry days when I am buffing I get zapped all the time. I usely rest my leg on one of the lathe legs.
This is time of the year where any friction will set up a charge.
walta
That does not sound like static to me!!!!
The next spark could be fatal.
Unplug the lathe until somebody with a meter can test your lathe for leakage to ground. and test the ground on your outlet.
It could be static if you said you were touching a running ungrounded dust collection system with one hand and holding the wrench in the other.
Is the lathe plug directly into a wall outlet, or are you using extension cord?
Is the ground pin damaged on your lathes cord?
Is the lathe plugged into a 3 prong outlet?
Walta
darrin hill
think i found the problem... the pin on the ground pin in the plug was broken..
walta
It’s good that you found 1 problem. But the dangerous situation you described is only possible when 2 active faults are present. You need to find and repair the ground leakage also.
Walta
darrin hill
so how would i accomplish that?
walta
Do you have an ohm meter?
Walta
