I have some pieces of the redwood from Charlie Belden's "Share it Forward" project a while back and I finally got brave enough to try some of it today. Absolutely the first time I've ever turned redwood. Nice wood. Turns great. I started with one of the smaller pieces and turned a tulip shaped goblet (or whatever it becomes) but I have had to make a lot of design changes because some of the natural edge rim started breaking off. I hit it with CA glue only to discover it totally ignores it.
This one is going to turn out okay anyway, but the larger pieces have some serious grain separation/cracks that I'd rather hold together if possible. Is there a glue that will do it? I can't see getting epoxy into those hairline cracks.
Chuck, I have been so fortunate to have a lot of redwood here and have turned many pretty pieces with it. I have not had any trouble with CA being 'rejected' by the wood, and it holds strong. HOWEVER, where ever CA makes contact with the wood, there will be discoloration that shows when you put a finish on it. Put a sealer on before gluing...that will help a lot, but sometimes not enough. You might consider using CA thin as your sealer over the entire piece.
There's some useful info from the Gulf Coast woodturner's here:
I tried thin CA in several cracks and there was absolutely no adhesion. It may as well have been water. These are old cracks and I'm guessing there may be something in the cracks that is causing this.
I understand what you are saying about the stain and I'm prepared to do a CA sealer if necessary. I have done that a couple times. Each time I call and alert my wife beforehand because I have a tendency to permanently attach myself to the lathe.
Try Duco Cement aka airplane glue. Mix with some of the finest sawdust you have, let dry, sand and finish. It normally does not leave any discoloration in the wood like CA. As the saying goes "works for me"! Tom
Being as you've already spent your money learning, how about sharing with the specific name of Duco you are using. The make so many now.
I am assuming this is for filling only and NO structural use.
I am not and never will be a fan of CA. I am firm believer that anything that makes something like this convenient will not hold up well over time.
Because of this, every time I do decide to use it for some little thing mine is always bad so that makes it too expensive when you only get one use out of a 2 oz bottle.
I don't need the glue for filling, just to hold some cracks, mostly grain separation. The gaps are too small for anything except something thin like CA.
The airplane dope is interesting and I'll have to try that. I never worked with model airplanes. I couldn't afford the kits when I was growing up.
I have never had CA go bad. I have done some bad things with it... like gluing my fingers together. While I have heard that it doesn't hold up well over time, I couldn't say. Four years is the oldest "CA enhanced" piece I have. It's still holding fine. Most of what I turn will probably be in a yard sale or fire place before the CA breaks down.
I have a couple bottles of medium and thick that have been opened and in the refrigerator for 2-3 years and still fine.
The brand is "Duco Cement", comes in a green and yellow tube or small bottle. I think you can get it at Ace Hardware but some stores don't sell it, I'm told, because it is often sought by "glue sniffers"! I just checked the internet and it looks like there are several sources. A tube lasts a long time. I use it to repair cracks, flaws, voids not necessarily structural repair as such. As mentioned, by mixing with fine saw dust from your turning it fills the voids and does not leave any stain on the wood. I have never had a problem applying any finish over the repair. And I have never had a problem gluing my fingers together with Duco Cement!! Also cleans easily with lacquer thinner.
I've had CA go bad. It still seems to work but the joint is very fragile. I was teaching a mirror making class one weekend and the first morning everyone had mirror blanks flying. We used Medium CA with Accelorator like I always do. I suspected the glue so I bought some fresh glue for the Craft Center Gallery where I was teaching and all the problems went away.
