show me your calipers... homemade..
darrin hill
been working on a vessel and my calipers from wood craft are too small.. anyone care to show me theirs and how they made them?
darrin hill
Re: show me your calipers... homemade..
OK, here are mine. I don't like the figure 8 ones because they take two hands and seem awkward. Mine are scissors "like" and are easy to operate with one hand. These will reach eight inches, I think. There are a couple of "features" that make these wonderful to use. The Pivot is centered between the tips and the left end of the handles. So, when you open them the handle end opens as much as the tips and you can see how far apart the tips are by making a scale on the handle end. Also, the two inner surface of the grip are made to be flush when the tips are closed. So, when you open the tips you can feel the change with your finger tips. Since that point is closer to the pivot, its not a one to one but is a ratio of the distance. This works much better than expected. I did not, but it might be very useful to grind or file some steps into the inner surfaces that are calibrated to known thickness. Maybe set the tips at 3/16" (whatever) and then file a little step flush, Then you could "feel" for it very accurately. I find feeling for the thickness to be much better than visually reading a scale and then translating that into cut or not cut.
These are made of acrylic sheet about 3/16" thick somebody gave me. If you have the tools and skills you could make them out of metal also. I had a smaller pair and liked them better but they went away. You can make the jaws any shape you like to accommodate the shapes you turn. These are set up for bowls more than HF's and one of the the things I like them for is reaching between the Cole Jaws to determine the thickness of the bottom of the bowl.
aluminum calipers *LINK*
Mike Foster
Below is link to mine. I made these years ago out of 1/4" Aluminum with a bolt and nylon nut to keep them tight. The wing on the top has scribe lines relating to various thicknesses. They are good for measuring from 12" to 24" deep into a form.
Calipers
Roger
Go to www.fredwilliamson.com, then to the methods of work section, check out the custom tools section. There you will find numerous sizes of homemade calipers. Check out the complet site while you are there. Very interesting fellow.
Roger
J Paul Fennell
Darrin,
If you need something for measuring the difficult area around the opening of a hollow form, check this page on my website http://jpaulfennell.com/Tools.html. Works great.
J. Paul
After an Ellsworth class in 1990 I began.....
JamieDonaldson
..making and using the type hollow form calipers that David used. They are still my most reliable gauges for both hollow forms and bowl bases, and when made from heavy galvanized wire they are very cost effective!
Where do you find "Heavy Galvanized Wire"?
Chuck Jones - West TN
I saw this described in one of Elsworth's books, but I couldn't find wire that holds the shape well enough to be effective.
If I remember correctly the technique is to measure the gap between the tips, then measure (or judge by eyesight) how much gap there is between the outside tip and outside of the piece.
I have a bunch of those too Jaime
I had to buy a big coil at either....
JamieDonaldson
..Lowes or Tractor Supply many years ago- was enough for a lifetime supply for me and every local turner I knew at that time! I originally knew it as clothesline wire, and it might be a good chapter tool making project, to share the wealth!
Re: Where do you find "Heavy Galvanized Wire"?
I also have several of those, but I made them out of heavy copper wire. Lowe's or any of the borgs will sell you as much or as little as you like from their spool of "ground" wire. Not cheap, but you only need two feet or so. I round o the ends after cutting it into smooth ends. The copper works well in that it doesn't have a lot of spring back and is easily shaped and reshaped by hand, but is strong enough to resist giving you artificial readings. Ground wire comes in two different gauges and for the life of me I can't remember what they are, One is a No. 4 I think. The smaller of the two works fine.
steve worcester
What are the three different diameters for?
Randy Gleckler
Ya know all those lawn signs for Ads, or Political ads, etc... they make great gauges.
Welding rods and brazing rods work well
Welding rod and brazing rod works well. They are stiff and about 1/8". As mentioned above copper grounding wire works well. You can also get aluminum rod in small diameters at places like Lowes, Fastenal, and Tractor supply.
For smaller projects I simply bend Coat hangers in a sort of C shape with a space set for something like 3/4 or 1". Then I just place a ruler on the outside and put one end of the c in the vessel. I measure the gap on the outside and subtract that from the 1" gap.
