200+ woodworking book reviews
respirators
respirators
respirators
Jean Fuder
I'M looking for a face shield with a respirator, and want to know what is the best for the money. Who have a Trend Airsheild Pro and do you like them? Thanks for any help you can me.
Re: respirators
Dale Jablonski
Re: respirators
dale jablonski
I have a Trend and it does do the job. However, I have found that it is somewhat heavy. I've got some neck issues and have found I can't wear it for more then about an hour at a time. Then I have to resort to a face shield and respirator mask. Good luck.
Re: respirators
Re: respirators
D. Hansen
I have had the 3M "Raycor", the Trend initial version and the Trend Pro. The Pro is the best of the bunch. Although it does weigh a bit more than the others for me it is better balanced in that the batteries are at the rear of the case and I can wear it all for as long as I want to turn in a day.. It also is better built overall. Checking the filtration claims it is extremely efficient. I could not make an exact comparison with the UK and USA measures but it up at the top. The visor is rated to take a heck of a hit. The down side is that the filters are pricy. the Pro is so much better than the initial version I would not even consider the older issue. I find the battery warning and the life of the battery great. I can't take much more turning in a day that which the battery allows.
Re: respirators
Chuck Jones - West TN
I like my Trend Air Shield Pro
I found it a little cumbersome to get on and off at first, but I soon reached the point where I could do it without my wardrobe assistant.
Weight has not been noticeable to me.
I bought a second battery, but I could have actually gotten by without it with very little compromise.
Don't like the stick on protective sheets. They seem to distort my vision a bit. I don't use them anymore. I'm just very careful about how I clean the face shield.
Mine is about a year old now and heavily used and I still use the original filters. I blow the out sometimes, but they are fine.
If I had known about the 3m fanny pack model, and cost was not a consideration I might have gone for that one. But I didn't know about it and cost is always a consideration... or should be. As I recall the 3m model is much more expensive.
Re: respirators
Alan Zenreich
Re: I like my Trend Air Shield Pro
Alan Zenreich
I recently sold my AirShield Pro to a member of our local woodturning club. I rather liked the unit, but my wife and I prefer the 3M units. We have AirStream and Breathe Easy respirators, each has it's own strengths.
I found some pretty good buys on then (used) so I did not have to pay top dollar.
I have also found an alternate battery for the 3m units, it is much much smaller and lighter, and MUCH cheaper... making the entire setup quite desirable,
I would be happy to chat about the Trend and/or the 3M units if you like,
Re: respirators
where'd you get the batteries?
Re: respirators
Re: respirators
Bernie Weishapl
I have the airstream AS 400 and I really like it. It has a hepa filter in it and figured if they use it at the grain elevator it must be pretty good.
Re: respirators
Re: respirators
Jeff Brockett
I bought a Trend airshield pro four months ago and it was one of the best investments that I have made. Weight is not an issue at all and with an extra battery there is never any down time.
Re: respirators
Harry Robinette
Re: respirators
harry robinette
I just got my Airshield Pro and had to send it back. I tried it 7 times over 4 days and got a head ache ever time within 20 minutes. The unit seams great lots of air easy to see and no blurring. I have COPD and the Doc says I have to use something. Respirators are out cause I can't get enough air with the COPD.
I'm working on making a system like the Trend Airshield so we'll see how that works.
Re: respirators
Alan Zenreich
Re: where'd you get the batteries?
Alan Zenreich
Adrien,
I'll try to make some photo or a video of the new little battery setup this weekend. I'll supply details soon.
Re: respirators
Alan Zenreich
Re: respirators
Alan Zenreich
Harry,
I may be able to help with your project... drop me a note, I have some items that may be useful.
Re: respirators
Peter Charles Fagg (UK)
Re: respirators
For what its worth, I have used the Trend Airshield (NOT the Pro) for some years now and apart from taking out the batteries and putting them in a back pocket pack, (It lessens the weight) it does a very efficient job.
I would like to change to the Pro but costs are be prohibitive!
Regards Peter.
