Rikon 70-100 lathe
James Pittman
Is there away to make it run in reverse with out changing motor I would like to sand in reverse. Thanks Jim
Rikon 70-100 lathe
James Pittman
See latest AAW Journal
Chuck Jones - West TN
I haven't read it yet, but I received mine today and at a quick glance I noticed there is an article on the subject.
Just stand on the backside of the lathe
Or if it's spindle flip it end from end. However the article in the latest issue of American Woodturner is excellent.
Re: Just stand on the backside of the lathe
James Pittman
I do not do much spindle work ,maybe I am missing something if I stand on the back side of the lathe the fibers in the wood will still be turning in the same direction what I am trying to do is sand the fibers in a differant direction. Thanks Jim
Lyle Jamieson
There is an easier fix...use sharp sandpaper. Then there is no need to sand in reverse.
I agree with Lyle. I've been playing with sanding in each direction. Before that I've always sanded in one direction. You can't tell the difference in my pieces.
