Crush-Grind Mechanisms Questions
Ed Larson
I have turned several pepper mills using the traditional grinders. I would like to use the Crush-grind mechanism as it appears to have more design opportunities and may give a more consistent grind? I have some questions. All of the instructions say to remove the tabs and glue the mechanisms in place. My guess is that this might be better and simpler than cutting the grove and depending upon the prongs to hold?? Also I can find no info the describes the size and location of the grove if glue is not used??. Also has anyone use the shaftless crush grind mechanism and what are the pros and cons??.
Re: Crush-Grind Mechanisms Questions
Jorge
Ed,
I only used the shaftless mechanism, it's advantage is you can make the mill as short or as tall as you want, I made it tall to hold lots of pepper. I did not cut the tabs, I did cut grooves with a pencil exacto knife and epoxied the tabs in place.
The disadvantage of this set is you need to make 3 pieces, the advantage of the set with a shaft is only two pieces.
$0.02
Jorge
Steve Criscenzo
Ed
I have been using the crush grind mechanism for about a year and have made about 15 of them. All the recepients like them (or at least that is what they tell me.)
I tried one using the tabs to hold the bottom in and after a few cycles of removing and reinserting the lid the bottom pushed out a bit. I now glue all of mine in and have had no problems.
I like the fact that there is no shaft through the top on the crush grind unit. This makes alignment much easier and there is less chance of binding. I have made some tall ones and found that I had a bit of drift in the center hole. To counter this I now drill the thru hole (1 1/16) from both ends and I have found that this make alignment a snap.
Since the crush grind mechanism can also be used for salt, I have made several matching salt and pepper sets. I inset a bottom on the top of each (different woods) so it is easy to tell them apart.
I have not used the shaftless unit. I have seen mixed reviews on it.
One last hint. I sand a slight taper in the top of the shaft and them put a bit of wax on it. I find this makes removing and replacing the top much easier.
Have fun with it.
Steve
Chuck Jones - West TN
No more crush grinds for me!
I have made a couple dozen and I've had numerous problems with them.
Some of the problems were maybe because I have a lot to learn about gluing and some were because I used wood with too much natural oil and the glue would not hold.
But I've also had a couple where the gripper that holds the top mechanism to the shaft has lost its grip. Guess what happens when you pick up a pepper mill by the top and the top comes loose over a large tureen of soup.
I like the ceramic grinder better, but not enough to put up with the headaches. I just bought a batch of the old fashioned mechanisms.
Jim Evans
Re: No more crush grinds for me!
Jim Evans
I have had good luck using JB Weld or Epoxy. Never used glue because of what you have experienced.
I also drilled the hole in the top deeper in order to make sure the shaft went all of the way through the plastic insert.
Dennis in Southern Oregon
I have made several mills using the ceramic crush grind mechanism and am now quite happy with them after having overcome a couple of problems. A couple of tips: (1) don't drill the recommended 1-1/16 inch hole in the top end of the mill base, because it produces a sloppy fit with the plastic piece that goes into the lid. Instead, drill a 1 inch hole and carefully ream it with a side-cutting scraper or the wing of a gouge to get a proper fit. (2) As someone else mentioned, make the hole in the lid deep enough that at least 1/4 inch of shaft protrudes from the top end of the plastic retainer that fits into the lid. I have good luck with 5-minute epoxy to cement in the mill mechanism and the the plastic retainer in the lid.
Dennis
Joe Herrmann
There will be an article in the next issue of Woodturning Design magazine on making a Crushgrind peppermill. The author notes that you should never break off the tabs and provides instructions on how to cut the required grooves.
Joe
Me neither!
Tony - memphis
I went through several last Christmas at crunch time and they didn't work very well. I was very frustrated as they are expensive and I had high hopes. My issue with them was that they just didn't work well. That'll teach me to try something new at the last minute!
Tony
Re: Me neither!
Bob Hans
AND if they fail thee 25 year warranty is non exsitant. I had two fail in the last couple of years. I like the idea, but I am suspicious of the quality
GaryG in MD
This will be good to see, Joe.
I came to the same conclusion just from reading the so-called instructions -- before ever even starting to make one.
It's obvious that the tabs are necessary and that they have to go into a groove.
I made a "groove tool" out of a big Allen wrench, and I hold it in a Hosaluk 3/8" boring bar in my Don Pencil pistol-grip arm brace. Very quick and easy -- works great.
I like the idea of the Crush Grind mechanism. I believe that there are definitely problems with the Crush Grind experience because of poor and incomplete instructions, but I also believe that the problems can be worked out, so I'll be very happy to see your article (as a dedicated subscriber, of course!).
I hope your article is written so the mill is first made in one piece to preserve a grain match and to make the shape transition across the top/body boundary continuous -- I worked out a simple procedure that does that. (This is important if you use a laminated blank.)
I also agree that it's best to use a 1" hole, not the indicated 1-1/16".
In softer woods, I also fudge the 1-9/16" to 1-1/2" to get a tighter fit on the lower grinder mechanism.
Keep up the good work! ...Gary
