Re: LEDs and thin turning *LINK*
Craig Daymon
I'm guessing what you are talking about is a light that sits on the turning tool near the tip at the end of some sort of cable? I think it has been done, but I don't know if it has been done commercially. I think part of the issue, at least this was true a few years ago, is that LEDs don't produce nearly the light that conventional bulbs do, at least without bundling several together (lumens). A better approach, if this is still the case w.r.t. the the lumens produced, might be to use fiber optic cable with the light transmitted down the cable from a more powerful source. The cost might be higher though.
Woodcraft currently has a 7 LED, 2 power source, gooseneck light with a magnetic base on sale for $24.99. (It takes 3 AAA or 110 AC. Personally, I like not having to use batteries.) I'll probably pick one up soon as I need more light at the lathe. They don't give the size of the head, but it looks a bit big for an Ellsworth opening. It produces 180 lumens.
-Craig
Woodcraft 7 LED gooseneck light
