laser rigs revisited
Mike Foster
Well I looked at all the options and must say that both the Sinner and Monster rigs looked good. Both Jeff Willaford and Tony Wheeler gave me a heads up on a new laser rig that Jeff Salter has come up with. I got in touch with him and he emailed me some photos of his rig. I was instantly hooked. The attachment to my Jamieson D handle was simple and solid and the adjustment for positioning the laser was also simple and solid. But what really sold me was the rotation of the laser light offset about the set point. Hard to describe in words so I attached a couple of pics that Jeff sent me. I was going to take some photos of the rig, but didn't get around to it so I just used Jeff's.
I turned a HF yesterday and could not believe how nice this was to use, especially in comparison to my home-made job that was not user friendly. Generally I would have to stop and change the offset of my laser rig frequently to stay perpendicular with a tangent of the curve. If you don't, you would run the risk of a steadily increasing or decreasing wall thickness and possibly end up cutting air. Jeff has come up with a unique solution to this. All you have to do is set the laser, with no offset at the tip of your tool, dial in the offset for the wall thickness you desire, then rotate the head to stay perpendicular to the tangent. You don't have to remove the tool from the HF to change the angle, so it really speeds up the process. I also think it actually is more accurate and easier to get a nice smooth interior surface.
The laser that Jeff has used is a sealed laser. It looks similar to the ones used with the Monster and Sinner rigs, but he said he wasn't sure that it was the same. Batteries and switch is remotely located at the other end of the arm like both the other rigs.
I would post a pic of the HF, but it is sealed with Anchorseal as I left the walls about 1/2" with the intention of carving on it later. It was a blank of magnolia that I got in a trade with Donna Parrillo in RI.
I am not promoting Jeff's rig, just a happy customer. He stated that his first production run was 25 units, and he only has a few left. I think he is going to do a larger production run shortly.
