Re: Walnut crotch
ronnyeelen
Thank you all for the comments. Appreciated.
I will take a photo of the underside this weekend, and put here.
In fact, it a round bottom, no foot.
The 80grit inside surface is fun to experiment with.
Next time I will use 60 grit, to get an even more obvious effect.
The difference with a wire brush would be that the wire brush would still be revolving on a drill or something. So it will create a rough effect, but as the wire revolves, the different 'hairs' will kind of cut accross the grooves made by the first hairs.
With the sandpaper held in place, it is always the same grit pattern which touches the wood and finally leaves a marking according to that pattern.
Ronny
