To Vacuum-Chuckers using a Gast Model 0523 Vacuum Pump:
I am a "spare parts on hand" kind of guy, and have been watching eBay for 8 or 9 months for rebuild kits for my two Gast 0523 Vacuum Pumps, just to see if I can get a rebuild kit or two inexpensively to put in inventory for when I eventually need to rebuild the pump(s). I recently found a seller ("aqwholesale") who was offering new OEM Gast K 478 rebuild kits (which contain 3 new vanes, 2 new O-rings, 2 new foam filter elements, and a new "head gasket", plus instructions). Before posting this, I wanted to confirm that the seller supplied the correct kits, and in new condition. They arrived fairly quickly via USPS today and are in great shape; mine have OEM packing seals on the kits dated July 2011.
This information is being provided to those turners who might want or need to acquire a Gast vacuum pump rebuild kit (K 478) for use with the 0523 series of pumps. (This is the vacuum pump model sold by Craft Supplies, Packard Woodworks, etc.). I have no previous or subsequent knowledge of the seller, and have no financial interest in promoting any sales for him- just a satisfied customer at present. If anyone needs one of these kits, there are apparently several still available at the link below. As with anything on eBay - Caveat Emptor.
I hope this helps those of you that might have a need for such an item!
I recently rebuilt my pump using a kit ( from a different supplier in the USA) but was quoted over 10 TIMES that price from the Distributor here in Australia. So they are cheap.
I picked up a vacuum pump at an auction a couple of years ago for $5. The previous owner was using it as a tire pump! It looks just like a Gast pump, but the manufacturer's label is obliterated/unreadable. Is there another way for me to identify the pump as to make and model, in case I need a kit sometime?
...If I were you, some night when I was really bored I'd try internet searches for vacuum pumps and compare pictures until I found one that looked like mine. You might get lucky, or very disappointed. A good place to start would be gastmfg.com to see if yours looks like any of their models. Good luck.
It's searches like that that have made me suspect my pump is a Gast. It has a GE motor with quite readable ID and specs plate, and a plate with a serial number, but there is a light-coloured rectangle on the top where (I presume) the maker's sticker used to be. Rough handling by the auction folks broke one of the glass filter bowls and I haven't replaced it yet.
The reason I posted in this thread is that I have no idea how old the pump is nor how heavily used/abused it may be, so it could need a bit of refurbishment to work optimally.
Found your post with pic on the $5 vacuum pump through a Google search for Gast Vacuum Pump. Did you ever identify the model number? I have one that looks like an exact match for the pump but not for the motor. I think the photo linked will show in the post. The ID plate on the top identifies it as 2M8009 Travenol Vacuum Pump and as best I can confirm Travenol was a medical equipment supplier but is now defunct.
Because there is no longer a label on my pump, just a serial number and the motor information, I can't be sure that it really is a Gast. The motor is a GE one; the pics I posted were pathetically blurry, though.
Check out the Gast 211 series - I have repaired a number of these pumps used frequently in science labs (biology & chemistry) over the years. The heat dissipation fins on the head of the pump may have changed design over the years (yours might be different than the current model), but the same basic parameters, and hopefully parts, would be similar. There are exploded diagrams of the pump head and associated parts (gaskets, vanes, filters, etc.) that might help you in a pump reconditioning and restoration to rated service.
More information at the link below.
Good luck!
Rob Wallace
(Long-time lab-rat, and resident lab equipment mechanic for 35+ years)
Thanks, Rob. Is there a way to tell from the serial number what kind and/or model of pump it is? Actually, I'm kind of hoping it isn't a 0211, since the flow rate for the 0211 is pretty low (1.3cfm); at the least, I'd have to seal porous wood before turning it.
Short of contacting Gast with the information you have, and asking them if they were producing pumps for the medical company, I'm not aware of any other way to ascertain what the model might be. The pump size, head casting, fittings, and oil/filter cups say "Gast 211" to me, and the relatively small head size likely is only able to develop the lower cfm rating you mention. I have two of the 0523 pumps, which have adequate flow ratings for most vacuum chucking, clamping, veneer presses, etc.. The Gast 0823 and 1023 models would also be fine, and are probably more cfm than most turners would need. I agree that the smaller pump is not likely sufficient.
Check-out eBay for the "23" series of Gast vacuum pumps which regularly appear there. I bought my first 0523 as a "used" pump, but it was never put in service - it still had the factory plugs in the inlet and outlet ports. I payed only $115 for it, including shipping. The second 0523 pump I got through eBay was in excellent shape - it bid to about $62, with another $ 28 to ship. This might be a less expensive route in the end compared to trying to recondition and put a small, low capacity pump into service.
I looked in to getting an 0523 from Surplus Center a couple of years ago, but the shipping and import brokerage fees were going to pretty much double the cost. I probably should have just ordered it anyway, but I was too peeved by the US and Canadian delivered-price difference to think clearly about it!
