Have a question? Ask Woody!
Help attaching silicone stopper to dowel
Jack Savona
I have a ribbed silicone plug on a wine stopper I made for home use. Every once in a while, when someone pulls the stopper out, the silicone plug remains in the bottle's neck.
If I sell any of these stoppers, I'd like to know customers don't also have this same problem. So, what can I use to permanently adhere the ribbed silicone to the dowel inside it?
Re: Help attaching silicone stopper to dowel
Jorge
Jack,
I don't know about attaching silicone to a dowel, but Ruth Niles sells wine stoppers that work beautifully..
www.torne-lignum.com/
Jennifer Indy.USA
Jack if you scuff up the dowel with some heavy grit sand paper that keeps them on. That's what I do and I've not ever had a problem with them. I do recommend Ruth's if you want a higher end stopper. I make the silicone ones for quickie gifts and giveaways.
Jen
david
Jack:
I liked the idea of using those silicone stoppers and had the same problem/concern. With silicone, not very many things adhere to it. I think Jennifer has a good idea in roughing up the dowel. It has been a while since I made wine stoppers, but it seems like using some uncured silicone from a tube as an adhesive might work in conjunction with roughing up the wood. The uncured silicone may have better adhesion with the cured silicone of the stopper. If you do try this, I would be interested to know if it works :) :D.
Barbara Gill
I used to use the silicone ones until Ruth developed hers.
Emmett Manley, Lakeland, TN
I just tell people the stopper may separate at some point -- if so, just put it back together with a couple of drops of whatever glue they may have.
Re: Couple of Drops of CA Will Do It...
Bill Neddow
In a perfect world, removing the silicone stopper from the dowel would be impossible because of the vacuum created by trying to pull the two parts of the stopper apart. Unfortunately, the world (and the wood dowel) is not perfect. Air leaks through the pores in the wood and along the small scratches on the side, breaking the vacuum. Another solution besides the ones mentioned, is to rub a drop or two of wet marine grade silica caulking compound on the dowel. Then pop on the silicone bottle stopper. The caulking seals the pores of the wood and fills all the little imperfections, making a perfect vacuum. I use clear marine grade caulking compound I get in a little tube from the hardware store for a couiple of dollars. Regular grade would probably do, but I find the marine grade tends to adhere better.
Thanks, everyone!
Jack Savona
I'll try your suggestions, see what works and report back.
