actually turned something last night
Carol Reed, Strawberry, AZ
I'm supposed to be packing, but...right after I move, I have a class with Cindy Drozda, so I have to set aside the things I will need. I want to use my new Hunter tool so I needed a handle. I also have been playing around making the aluminum tool inserts thanks to machining lessons last year.
The wood is an odd piece of redwood of all things. It was about the right size. It took a wax job well and fits my handle like a glove.
Not much, I know, but occasionally one should post their credentials, such as they are. :)
Re: actually turned something last night
Nicely Done, Carol!  Very nice indeed.  :-)
Wally Dickerman
Carol, do yourself a favor and bore a hole in the end of the handle. Adding some lead shot will make the tool more comfortable to use. (Oh, you might turn a plug to glue in behind the shot)
If you don't have any lead shot come on down. I used to do a lot of skeet shooting and loaded my own shotshells. I have a couple of 25 lb. bags of #9 shot left over.
As I think about it, you would be right. Weight at the furthermost from the point of cutting would smooth overall operation, adding ballast to counter the cutting forces.
I am challenged in several areas here; first, time. I really am packing and leave one week from today. Heading to Pahrump, NV. No time to journey to Green Valley as much as I would love to. Time, also, in that I have little time to devote to this project before I leave, and Cindy's class is on the 18-19th for me.
Secondly, I need to order Doc Green's book on holding things. I have the most trouble mounting things on the lathe. There are undoubtedly a few items I need to add to my arsenal but time has been fugitive lately.
Now, a question. I can probably get some shot around here. I have yet to epoxy the aluminum insert in. Could I just drill a deeper hole and load the handle with shot, epoxy it all together and call it done, or would the weight not be as well place as if I found a way to mount it on the lathe and drilled from the end?
If I were to drill into the end of the handle, how do I hold the thing? Lathe, drill press, what? How? For that matter, how would I hold the thing if I were to deepen the insert hole? Color me flummoxed here.
As to the plug, I'd tend to a brass cap from the plumbing department for a little class this project certainly does not need, but it would be fun.
Mike Stafford
It might be a bit late to do lots of drilling....
Mike Stafford
but I would recommend drilling the business end deeper so that you can vary the projection of the swan neck Hunter tool. I have found that I get better results with the #3 swan neck by varying the projection depending on the density of the wood I am cutting. If the wood is dense and you are getting chatter you can choke up on it (i.e. slide the shaft a little farther in the handle and shorten the length sticking out). That allows to reduce the amount of chatter.
I don't put any lead in my handles but I useheavy dense wood for my handles in the first place.
Wally Dickerman
Carol, that's a very short handle so it really won't matter where the shot goes. Redwood is a very lightweight wood. The shot will help a lot in making a stable tool.
I add shot to my heavy duty scrapers. Makes for more stable cutting. (You used a couple of them yourself when you were here)
Re: handle do-over
OK, if I get a chance to redo this, here is what I am hearing:
harder, heavier wood, longer handle, weighted at the end, and drilled deeper at the business end to vary the extension of the cutter.
Anything else, folks?
But I did enjoy what I did do. Sighhh....
Dale Jablonski
Re: handle do-over
dale jablonski
If it works for you and brings you pleasure using it "don't fix it if it ain't broke" make something else.
Mike from St. Clair Shores
Wally,
You mentioned you have two 25lb. bags of shot. Have you checked the prices of shot lately? You might be sitting on a small fortune. ( depending on when you bought it, the price has went up significantly).
Phil Stivers
Phil Stivers
Nice. Looking forward to seeing nt soon.
