ADVERTISE HERE - FREE TRIAL
Silver soldering
Silver soldering
Silver soldering
robo hippy
Any one know about this? Technique that is a step under brazing like they do with carbide saw blade tips. I am looking into making some scrapers like the Big Ugly tool that is traditional to the Oregon myrtle wood bowl turners where they would silver solder tantung steel onto both ends of square bar stock and wear a heavy glove on the handle hand. I have a source for Stellilte (tangtung is very difficult to find), which is almost as hard as carbide, but can be resharpened. I don't think CA glue would be strong enough to keep me comfortable.
robo hippy
Re: Silver soldering
Bill Howatt
Can't help too much but while it is called silver soldering it is really silver brazing. Another term often used is hard soldering as opposed to the typical soft soldering with the lead-tin alloy that was commonly used and now replaced with a lead-free alloy.
We used to do it with a propane and oxygen torch which generated enough heat. A regular propane torch isn't hot enough. MAPP gas torches can also be used.
There are various alloys of the solder and the stuff we used was about 1/16" or a bit more in diameter and came in rolls. A flux is required and the flux we used was a white paste. Some of the flux you get with the lead-free solder these days looks very similar. In fact you have to be careful when looking up silver solder because you may get references to lead-free soft solder.
I would imagine you can get the material at a store that carries general welding supplies.
I'm sure somebody more knowlegeable will give you some help.
Bill
Re: Silver soldering *LINK*
Bill Turpin in WNC mountains
Here is a link to a WC article written several years ago.Unfortunately the prices have gone up. If you have any more questions, please PM me.
Bill
WC article on SSolder
robo hippy
Thanks, that answers some questions. Now to research it some more to see if it is some thing I should attempt, or have some one do for me. My shop has too much wood stuff for open flames.
robo hippy
Your shop can't be much messier than mine. I clear off a 2 foot area around my metal vice. I purchased some fire bricks from the hardware store. If you have those you can simply lay the parts on there. Not only do they heat up faster, it protects your workbench and other areas.
I've made quite a few of the silver soldered HSS tools. They are easy to make. Just clean the joint well and use lots of Flux. Then heat the metal near the joint so the silver flows into the joint. It's hard to silver soldering on jewelry where fire scale and any small bubbles will really show. It's easy to just stick to parts together if appearance is not an issue.
David Walser
Robo,
Bob Rosand uses silver solder to attach the cutting tip on his bent angle tools. I have one of his tools and it has proven to be very durable. These tools are used for hollowing small forms, so what you have in mind might involve greater stresses. Still, my experience leads me to believe that, if your tool fails, it won't be the silver solder that was at fault.
By the way, Bob's tools are an excellent value at $20 plus shipping.
Here's a link to Bob's website so you can see the type of tool I mentioned above:
http://www.rrosand.com/tools.shtml
Harry in beautiful downtown Kulpsville
And if/when you wear the tip down, he will replace it at no cost!
