Lawson
Lawson
Lawson
Mike Foster
This is another in the minimal surface series. I came across a digital representation of the form and started thinking about how I could pull it off. I was hooked as I came up with a way to create the form with very little carving. After an initial failure, I solved some problems and came up with the piece. It does not really have the visual appeal of some of the other forms, but the challenge of turning it was was too much to resist.
It was turned out of some pretty bland butternut, so I thought, what the heck and tried the vinegar and iron method of ebonizing thinking I would get a light ebony surface with some of the butternut grain showing. Not so, it was black. Man does that technique work (my first try at it). It looked OK glossy black, but I figured I could improve on that, and carved the texture through the ebonizing. It was a fun piece and a good learning experience.
Butternut with vinegar and iron ebonizing turned on 7 axes
8.5" x 5"
Re: Lawson
Re: Lawson
Mike from St. Clair Shores
mike, I really like what you were able to come up with. Carving thru the ebonized butternut really creates a contrast. What bit did you use on the carving?
Re: Lawson
Re: Lawson
Mike Foster
Mike, I used a Ryobi power carver that holds carving blades (Flexcut) shaped like other carving tools but fit into a chuck in the carver. I used a small gouge some might call a veining tool.
Re: Lawson
Re: Lawson
Hal Taylor
Great job. I love the texturing - turning ain't bad either.
Re: Lawson
Steven Antonucci
I don't see seven centers in the picture
steven antonucci
Unless I am not translating the 2D into a proper 3D object, I can't find seven centers?
Where are they?
Steve
Re: Lawson
Ditto what Steve said
Re: Lawson
Leo Cuellar
Hmm, looks triangular on the long axis...
Leo Cuellar
which is probably where the other 3 are.
Re: Lawson
This explaing the SEVEN axes?
charlie belden
Imagine a three sided column - all three sides the same width.
Curve each face ( 3 centers).
Now turn holes square to each curved face (3 more centers)
Finally, using the centerline of the top and bottom of the column,
round off the top and bottom of the column (1 more center)
3 + 3 + 1 = 7
Is THAT the way you did it Mike?
Re: Lawson
Re: I don't see seven centers in the picture
Mike Foster
Charlie hit the nail on the head. Here a a couple pics of the mounts.
Re: Lawson
charlie belden
Figuring out the centers was easy. Trying to figure out the sequence and holding method? That had me stumped - 'til your photos showed that part.
To think up ways to make the minimum surface area pieces you've been doing is probably a lot of fun. That you actually MAKE the pieces . . .
Re: Lawson
Steven Antonucci
Thanks for posting
steven antonucci
I didn't see it as a three sided piece originally (until Charlie mentioned it), and I also didn't realize that it had holes on all three sides. I thought it was a "vessel", but I am guessing that it is more solid at the ends than hollow?
S
Re: Lawson
Re: Lawson
Ace Foster
I'm having some difficulty seeing this as a minimal surface. Does this surface have a name?
A lovely piece in any case.
Re: Lawson
Yeah, it's solid
Mike Foster
Couldn't figure out a way to hollow it, actually didn't even waste my time trying as I don't think it would be easy. Could make a pretty effective club as it has 3 nice handles.
Re: Lawson
Oddly enough it's name is
Mike Foster
Lawson. Named for the mathematician who described it. There are references to the math involved out there, but it is way over my head so I don't bother. I just happen to like the concept of minimal surfaces, the idea that they can be described mathematically, and I like the forms that can arise from the math. Here are a couple of links that give more explanation about the Lawson surfaces. I have an inkling that these surfaces may have been originally invented by microorganisms and that the penetrations may also have been observed in nature. I have not found a reference to that, but am just extrapolating from the name of this class of minimal surfaces (vesicles) and the idea that a simple microorganism is basically an enclosed form with a flexible skin that, seems to me, would seek a state that would seek to enclose the contents with a minimum surface area. These forms just seem a bit more organic to me than some of the other minimal surfaces. Anyway, I ramble, here are the links:
http://www.chem.ucla.edu/~michalet/papers/lvmh/e-more.html
http://www.chem.ucla.edu/~michalet/papers/lvmh/e-gallery.html
Re: Lawson
Steven Antonucci
You could hollow through the ends"?
steven antonucci
If you turned an entry hole on either end, you could turn a round, triangular hole (pointy bottom) and hollow through it to get out most of the weight?
(you can hate me now...)
If you figure that out, I'll challenge you to hollow the inner legs next ;)
Steve
Re: Lawson
Probably could do it, but why?
Mike Foster
Just to say I did? Naw, it wouldn't add anything to the object. I think you are just trying to test the limits of my turning skills, or idiocy. Here I thought I did pretty good just completing the form with minimal carving.
You did get me thinking on my walk in the woods with the dogs about the objects we turners make. Seems they are mostly "walled" objects of some sort. I think it has it's roots in the utilitarian objects that were made in the past, bowls and boxes and the like. My sense is that the "hollow form" is a recent phenomenon, probably due in large part to David Elsworth. The other factor that undoubtedly has an influence is the nature of our medium. Wood, especially wet wood, does not like to be left thick and, especially, uneven in thickness. However, there are a lot of very large wooden sculptures and carvings out there. Obtaining stable, relatively dry wood that is thicker than 16/4 can be a real search and certainly not cheap compared to that tree that just fell in my woods. But it can be done. Species of wood has a lot to do with it as well. This chunk of butternut had been hanging out in my unheated cellar of the barn for a couple of years. It had been sealed, but it was relatively dry when turned. I didn't get wet turning it, but the shavings were slightly damp. It showed no sign of wanting to check as it lay around the shop (for a week or so) being carved and shaped before getting the ebonizing treatment, followed by a tung oil/varnish mix. Of course I carved through about half of that and have left it as is for now. (once the oil cures, I'll hit the whole thing with some fixatiff). Just seems to me that we limit what we do on the lathe, but there are other possibilities out there.
Re: Lawson
Re: Oddly enough it's name is
Ace Foster
Thanks. These kinds of things pique my interest, too, but my math isn't up to very much exploration. Alas.
Re: Lawson
Steven Antonucci
I think it would look cool?
steven antonucci
Aside from the technical challenges, I think that you could pursue it to intersect in the same way through the middle that the other three holes do (and from both sides).
I see a triangular donut with a funnel intersecting the three holes...
And, yeah, it would be wicked hard ;)
(gotta keep challenging yourself?)
S
