Posted a shot of this piece as it came out of the soak a little while back. When finished, the stain was not very prominent, so I hauled out my Graeme Priddle wood vaporizer and, following the outline of the stain pattern, burned a random cross hatch on the inside, and a unidirectional dash pattern on the outside. Light source from behind is needed to show the translucence. Cook Pine, 21" in diameter, 4" tall.
I just measured, and it is 3/16" to 1/4" thick. Not bad for this size, as just the weight of the cantelever can be an issue when the piece is wet. As it is, I cannot remove the tenon on the first day, as the pressure of the live tailstock can punch through the bottom--have to wait until the wood is harder and more dry. Vacuum chucking doesn't work because the wood is too porous.
It looks like it would be much thinner, but I know how well NIP transmits light, so I knew it was probably around 1/4" or 200/1000ths. When I cut a hat, I aim for 50-80/1000ths.
David when vacuum chucking something that thin with holes here's a trick I use. First I make a vacuum chuck that is 4" wide and 8 or 10 inches long. This way I only have to hold the bottom and don't have to worry about collapsing the whole vessel. then I tape plastic wrap around the area outside the foot. The vacuum will pull the wrap tight against any holes and seal itself.
Of course if the bottom where you are going to turn has holes this won't work but it has worked for many times to cover up bug holes.
