200+ woodworking book reviews
An Hour Of Alchemy
An Hour Of Alchemy
An Hour Of Alchemy
charlie belden
I like mixing things, ideas and stuff - an Alchemist thing.
Early on in my woodworking journey I learned of shellac. Not the premixed stuff you can buy in a can at your local Borg but the buttons and flakes of shellac you grind to a powder and mix with denatured alcohol. It's almost a magical thing, pouring the ground shellac into a small canning jar of DNA, screwing on the lid and swirling the elixer around to get the shellac to dissolve. After sitting for a bit - ok so it's more like hours, or days - the cloudy solution begins to have a clear layer developing above the clouds. That's if it's dewaxed shellac you started with. If not, in addition to the clear layer of color, there's a yellowish muddy layer at the bottom - the wax. Some more swirling and waiting and the clear layer's color deepens. Eventually the color intensity of the clear layer stops changing.
A funnel and a filter, along with a fresh clean new canning jar and it's decanting time - pouring off and filtering the clear layer the shellac elixer - disposing of what was left behind. With the jar lid screwed down securely a trip out into the sunlight reveals the wonderous result of the time spent practicing the ancient art of alchemy.
Now, thanks to the daughter of a deceased Old School violin maker and deceased Old School grandfather violin maker, I have new an interesting ingredients to do some more alchemy - Spanish Saffron and Madder Root.
In the last hour, I've ground some Madder Root in the coffee grinder I purchased specifically for Alchemy, sifted it through a kitchen sifter and then though a much finer sifter. Those who have ever had a kidney stone may have been given such a fine sifter by a doctor. The stuff that didn't go through the sieves wre returned to the coffee grinder and ground some more then sifted again.
The resulting small pile of very fine, almost smoke sized particles were gently and carefully slid into a pint canning jar of DNA where they immediately began coloring the alcohol a beautiful transparent red-orange-ish color that will get richer over the next hours and days of swirliing and resting. The result, after decanting and filtering will be a pint jar of a magic elixer, that at some future time be combined with another solution of Magic Stuff, that result then destined to be applied with a washed wool ball wrapped in a square of linen to something I'll make from a piece of a tree - yet another magic ingredient.
Now I'm wondering about the bark on the claro walnut logettes on the driveway. Surely the bark must contain some color that some alchemy can draw out . . .
Guess I should go clean up my Alchemists Laboratory (read "kitchen counter, sifters and coffee grinder).
Have YOU dabbled in this form of Alchemy. If so, what Magic Elixer have you found and what have YOU done with it?
Re: An Hour Of Alchemy
Try the rind from Black Walnuts!
Rob Wallace
Playing in the Chemistry lab.....
Rob Wallace
Charlie:
As a certified science nerd, I can tell you that at the present time I have about a liter of alcoholic extract of Argentine osage orange (Maclura tintoria) pigment (extracted from wood shavings) that I still need to concentrate, and another extract from padauk (Pterocarpus spp.) to do some experiments with these natural dyes on light-colored wood samples. I'm trying to research and test which compounds can be used to mordant these natural compounds, and will try to set up some experiments with different tests of color longevity and color fastness for these natural dyes used on wood.
I also have some extracts of the red pigment produced during fungal infections (of Hypsizygus ulmarius) in Boxelder (Acer negundo) with hopes that my colleagues in the Chemistry Department here at Iowa State can determine the chemical structure of this pigment (likely phenolic?) - it is my long term goal to determine if a specific compound can be applied externally to stop or retard the red pigment's oxidation(?) and fade from red to brown observed over time in this fungally-stained boxelder wood.
BTW - Extracts from walnut husks have been used as a natural stain (actually a dye) on wood for hundreds of years. I may also try extracting the alkaloidal pigments from pokeweed (Phytolacca americana) fruits; this species produces an intense purple-red pigment (betacyanin) which may be interesting to experiment with on wood.
With apologies to DuPont:
"Better things, for better turning, through chemistry...."
Rob Wallace
john lopez
In my wood stash there is a holly bowl blank that is crying out for pigment...
so I have some copper & vinegar in a sealed jar in hopes of getting a little verdigris after it reacts for a while.
link http://sca.livingpast.com/verd.html
It's all new to me but I do keep padauk, purpleheart and ebony around for colored fillers and maybe a dye experiment . Another species that seems to have potential for this type of work is Chak te .
Color seems to leech out of freshly turned shavings very readily.
Reading this thread is giving me a better idea of the potential and how to go about doing it.
I know of a turner in Australia who gives wood shavings to a group that uses alcohol extracted pigments to dye wool.
One question that occurs to me is will these pigments will fade with time
and exposure?
Woad
Jorge Castañeda
Charlie,
your adventures made me think of a weed very prevalent is my garden, woad, that was used to make blue dye; traditionally to make the dyes color fast, the mordant was alum (for textiles), I wonder if this would be true for wood.
Another magic potion is :mix pomegranate juice, an attractive red liquid, with alum and it turns black!
maybe an alternate ebonizing route.
Does anybody know how to make blue dye with woad?
Thanks
Jorge
Mike from St. Clair Shores
Charlie,
The title of your post really drew me in. I think that the experimentation that you do is pretty cool. The other thing is that on Monday of this week I got a shirt in the mail from a site called WOOT. They have daily deals on electronics, shirts, kid's stuff and wine. Well the shirt I got is with the word Alchemy printed so it reads the same if its turned upside down. Here is a jpg of the picture on the shirt.
Re: Woad *LINK*
Stuart Johnson
I had never heard of it but it doesn't look to be too complicated. I wonder how it would appear or even take on a light colored wood.
Woad Extraction
Thanks!
Jorge Castañeda
Thanks Stuart!
Yes, it does not look complicated, I had the same idea, a light dye in highly figured woods may make the grain pop, and in featureless woods to create some interest.
Re: An Hour Of Alchemy ('Shrooms!)
mjonesrdg
In your area, there is a bounty of mushrooms which produce a wide variety of colors. www.somamushrooms.org/dyes/dyes.html (Sonoma County) may be a good place to start for more local info.
Big bonuses come while foraging...the chantrelles and King Boletes are yummy, and a walk in the woods might turn up an up-turned dogwood, buckeye, or myrtle for your lathe.
I have seen native american art on hide and baskets that reportedly were colored with mushroom and berry dyes so there is some promise for long-lasting earthy colors. (Dang! this sounds like FUN!)
