Re: forstner bits in a tailstock
Dale Miner
My method is similar to John's, but I go a touch larger on the divot. I make a divot large enough that the spurs of the bit touch before the center point. Often, if the center point touches first, it will hit the grain in a spot that pushes the point to one side, and wobbling will result. When the spurs touch, there should be only one circle on the end of the piece. If there are two circles, then the bit is not hitting the center of the blank. This could be from a tailstock/headstock alignment issue, or it could be a result of a bent bit, or chucking inaccuracy. Regardless the source, I can usually make adjustments to some part of the system to bring the bit to dead center and start the hole. Snugging the quill lock a bit until the body of the bit is in the wood helps to keep the bit on center.
Even with the above, varying grain patterns and densities will cause the bit to track off center on a deep hole. If the hole needs to be dead centered and straight, then drilling undersize and turning to size is the best method.
