Bandsaw Sled
Bandsaw Sled
Bandsaw Sled
Chuck Bjorgen
I've been combing the Internet for ideas about making a sled for further processing bowl blanks on my 14" inch Jet bandsaw with the riser block. I think I've seen most of the sites that show these things and most seem to be about resawing for dimensional lumber. My goal is to safely split the log chunks--probably 12 inches long--into bowl blanks. If anyone here has made such a thing, I'd appreciate seeing your ideas.
By the way, I no longer own a gas chainsaw so that's not an option for me.
Re: Bandsaw Sled
Re: Bandsaw Sled
Rich Egan
The Carter Guides people had a bandsaw sled in their demo booth at AAW in June. It seemed to work well, and was reasonably priced, if I recall correctly. It was designed for processing lumber from short pieces of log, but would work well for your application. Make sure you have the right blade on your saw.
Re: Bandsaw Sled
Re: Bandsaw Sled
Jorge Castañeda
Chuck,
Dig on the archives, Dominic Greco posted a few years ago, a sled he made for processing small sections of trunk like you want to do and that worked very well, illustrated of pictures
good luck
Jorge
Re: Bandsaw Sled
Re: Bandsaw Sled
david
Several years back I made one from an article published in Fine Woodworking. Used it several times with moderate success. I no longer subscribe to this fine magazine--that was back in the world of the flat woodworking days, but I note that an anniversary issue--perhaps the 25th, mentioned this sled as one of the better ideas published in the magazine. You may not be able to find this article, so here is the basic concept: A flat piece of 3/4" plywood has rails underneath to fit the slot on the bandsaw table. The plywood just clears the position of the blade when slid front to back. On the plywood build two supports, front and back, constructed to hold a pipe clamp mounted SIDEWAYS say 6-8" above the plywood surface. The height and position of the pipe clamp depends on the size of the logs you want to cut. The pipe clamp holds the log in place on the plywood sled surface as it is guided through the bandsaw blade. The length of the plywood and the pipe clamp is what you want it to be. Wax all sliding contact surfaces to minimize friction.
Re: Bandsaw Sled
Re: Bandsaw Sled
Chuck Bjorgen
David, your description seems to be exactly what I had worked out in my mind and it clarifies a few things for me too. I already have a steel rail that is 18 inches that fits in the table slot. Thanks for the description.
I also looked at the log mill on the Carter site and for $140 seems priced okay but I'll try building one first. I had also seen Dominic's solution in the archives but it wasn't quite what I had in mind. Thanks all for the replies.
Re: Bandsaw Sled
Re: Bandsaw Sled  LINK????
Ricc havens
Does anyone happen to have the link to Dominic's sled in the archives? I couldn't find it?
Thanks
Ricc Havens
Re: Bandsaw Sled
Chuck Bjorgen
I found it by going to the main archive heading and searched for "bandsaw sled Dominic Greco"
