OT: New Cell Phone
OT: New Cell Phone
OT: New Cell Phone
Stuart Johnson
My cell phone has started going from a full charge to red alert and shut down in a matter of a couple hours. This is just an occasional thing but happens often enough to make the phone unreliable. I make phone calls, take a picture once in awhile and use the calculator at the grocery store so have no need for a smart phone. My problem isn't so much which phone to get but it seems they all use Bluetooth rather than a plug in type headset.
This might be like asking what is a good lathe or a good gouge but what is a good Bluetooth ear thing. When I go to the store I see people walking around with all sort of things plugged into their ears. Why they have to talk the whole time they shop is another topic. I want to find a very light weight one that has good crisp sound and a good microphone. In this case, without going crazy, quality if more important than price.
Re: OT: New Cell Phone
Richard Allen
Richard Allen
If you like your existing phone, except for the short battery life, perhaps instead of a new phone a new battery?
Stuart Johnson
Richard,
Thanks, I forgot part of my message. I took the phone in to AT&T and explained my problem. They said it was probably the battery and had a new one sent out to me. The same thing is happening with the new battery. When I called the support line (real English speaking ) they said they didn't think it was a battery issue but couldn't really do anything else as the phone was way out of warranty.
There is something going on that just sucks the charge out of the battery. I know when there is no signal or a weak signal the phone uses more energy trying to lock onto something but my wife has the same phone and with them sitting side by side she does not have any problem.
Sean Troy
Sounds like you have an application open. Even the older phones had at least a few apps.
Chuck Jones - West TN
Maybe "Bluetooth" is causing your problem?
I'm just plain ignorant when it comes to any of the newer gadgets, particularly those I don't need, but I had the same problem and my son told me it was because I had "Bluetooth" turned on and not using it. I looked in a mirror and my teeth didn't look blue, but I think he was talking about something else. Anyway he turned that option off and the problem went away... at least it got better.
Jim H
Things like wifi, bluetooth, & gps can drain batteries, but usually not that fast.
If you do get a new phone and want bluetooth, I have had the best luck with the Blue Ant brand, they are a quality product with superior noise cancelation. That said, most phones have a jack for a wired ear piece.
Harry Robinette
harry robinette
I had a verizon phone that did the same thing finally found out it was always roaming when I was at work,Had something to do with the building where I worked.Had to turn the phone off and just keep turning on checking and turning it off again.I no longer work in that building.
Stuart Johnson
We don't have roaming with AT&T but I think something similar might be the problem. My wife's phone is the same model bought at the same time. They were both taken off the chargers with a full charge last night around 11 pm. This morning about 6:30 am mine gave a couple warning beeps that say it is fully discharged and is going to turn off. The phones were on the kitchen counter within two feet of each other but mine showed network is active symbol and her's shows the 3G network is active. I don't know if the phone's antenna has anything to do with the network but the manual does say if it is covered it will use more power to try and get a good signal.
We are eligible for free upgrades so a new phone is no big deal but first my wife needs to decide if she wants a new one and if so which one. Deciding between a black rotary or one of the new colored princess was bad enough but a hundred or more cell phones might be more than the little gray cells can handle.
Steven Antonucci
Cyborg
steven antonucci
I think that the Bluetooth headsets are perhaps the silliest looking things ever invented? Only way that you could make it worse is to walk around the store with that thing stuck in your ear talking to yourself. I can sort of see it if you have it in your car while driving, but why couldn't you just answer your phone (or not answer it) if you are walking around a store.
I have a wired headset in my truck, and the wife's new minivan has bluetooth built into the dashboard. (in vehicle Bluetooth ROCKS!)
S
P.S. Agree that the Bluetooth is likely killing your battery life.
Re: Cyborg
Stuart Johnson
The one thing it isn't is a Bluetooth problem. I've never used one and the Bluetooth option has never been activated and is shut off. I've been trying to get some feel for a good one for use in the house. So many places ask for key pad input to get to the right spot it is too much of a hassle to make a call without some sort of hands free ability. In the five years or so we have had cell phones I think I've had 3 or maybe 4 calls while driving. I tell them to hold on and I pull over or just hand the phone to my wife if she is along.
I don't care for chit chat and actually removed my phone number from another site after receiving a couple calls from good intentioned fellow woodturners just calling to say hi. So I doubt if I'm going to be wandering around the store talking and bashing my cart into other shoppers.
Oh My Goodness
Barbara Gill
I agree with you again Steve. :D
Scott Hurley in N VA
I don't know where you live. However, if you're in a fringe area, and the phone needs to keep searching for a signal, that will kill the battery in a heartbeat. it can also happen if you're in a heavily shielded building, or a restaurant that jams cellphone signals (we have one in here in Northern VA).
Steven Antonucci
What is this world coming to?
LOL
