REAL MILK PAINT
Osage Orange questions.
Ray Carson - Lawrenceville, NJ
Hello everyone,
Due to the recent hurricane that hit NJ, there has been wood for the taking for turning around my way. I got my hands on a small piece of Osage from a downed tree that is about 14" long, 10-12 in in dia. and has an odd shape like a kidney. The heartwood is tight and I imagine the shape was caused by the elements or an obstruction.
Questions:
Are there any irritation hazards when turning?
Does the wood remain sticky or emit the milky white sap that appeared after I salvaged the piece with my chainsaw?
Are there any types of finishes that work best / or should not be applied at all?
Do I dry this like any other species? (cover ends in a sealant and let sit for a while before turning)
Is Osage Orange a hardwood or softwood?
Should I peel the bark off and then apply my pre-turning sealant?
Is this a food safe wood once coated with a finish?
I appreciate the advice as always and who knows, someone here might receive a Secret Santa gift made from this beautiful wood. I can't wait to start turning.
Ray
Re: Osage Orange questions.
Ray It is a very hard wood. I treat it like any other wood. Be aware the color will not last. It will go from bright yellow to more of a deep yellow in some areas and other areas will go tan. then over the years the whole thing will go tan. I still like the color. kind of reminds me of Danish furniture. If you keep it out of direct sun the yellow color will take years to fade.
Steven Antonucci
Don't listen to John!
steven antonucci
Osage Orange is a soft wood, if you are used to turning granite...
As John mentioned, the color fades, and it's harder than woodpecker lips. The little bit that I have turned didn't move much at all.
Steve
john Veerkamp
turns a lot like mesquite. It is hard, but cuts very nicely. It takes high gloss with just sanding and wax. I use oil to bring out the chatoyance and then wax. One of my favorite woods. The milky sap is only in the outer sap wood. It is not toxic or irritating. Turned green it is easy. It will split around the pith though.
John
Emmett Manley, Lakeland, TN
I agree with all of the statements provided by others. Osage orange is dense, heavy, and hard but finishes like glass. The pith will crack and the wood will eventually turn a dark brown.
Chuck Jones - West TN
I have a lot of it lying around and I've turned quite a bit. I like the orange color and I LOVE the aged carmel brown color.
I agree with what the others have said except I seem to have a lot of problem with it cracking early on after cutting, then it seems to settle down.
It has a bunch of names: Osage Orange, bodark (from French bois d' arc), bodock (southern variation), hedge, horse apple, hedge apple, et al.
Re: Osage Orange info.
I have to agree, this little log weighs a good amount. And when I rapped the end with a hammer, it was like hitting metal on metal. A dead solid..."PING." I also learned a new word today, "chatoyance." Me thinks I'm going to strip off the bark and seal the whole thing until I can come up a good use for this little gem.
Thank you for the information everyone.
Ray
Ed Moore in SW VA
If this piece of osage orange still has the pith, split it asap or it will check. Then seal it.
Ed
Katherine Kowalski
Katherine Kowalski
Ray,
In addition to what everyone else has said...
When Stuart Mortimer came down to our club last year in northern Colorado, he said his favorite (local) wood was Osage Orange because it was super hard, cut like butter, and holds carving detail superbly well! (I can only but agree!)
Stuart is well-known for his hand-cut twistwork, and it was delightful to see him create a lidded goblet from Osage Orange, complete with twisted finial and stem. I still have the Osage Orange goblet that I turned in his class. (Here's a look at it, if you'd like to see: http://katherinekowalski.blogspot.com/2010/09/2010-rocky-mountain-woodturning.html)
Without finish, and exposed to minimal sunlight, the piece has indeed darkened to a caramel-apple brown. But lovely it is!
Here, a lot of folks will make Osage Orange into utility bowls, so it is food safe. Haven't heard about any specific wood allergies, but always wear dust protection gear, (as with any wood).
All-in-all, a pleasant and surprising wood to work with. (The grain lines are prominent and quite beautiful!)
Katherine
Craig Daymon
From what I've heard and experienced, it will turn very nicely IF it is still wet. Once it dries (which is likely to cause checking), it will become MUCH harder to turn and you will have to take many trips to the grinder.
I haven't seen it, but I've heard that cutting dry osage on the tablesaw will sometimes throw sparks. This stuff is really hard when dry.
John Veerkamp
Even very dry old OO is very nice wood. I just turned a bud vase from the top of a 90 year old OO fence post. The interior is just as bright as newly cut wood except where the cracks penetrate the interior. When dry you can work with amazing amounts of splits and defects and still keep the integrity of the piece,
Just keep in mind the old saying,.......
JamieDonaldson
....that if a farmer offers you an old osage fencepost to turn, you will find he's not your buddy! >(
Can't blame a farmer
John Veerkamp
it is my own old fence post!
robo hippy
From an old farmer: "A black locust fence post will wear out one fence post hole. An osage fence post will wear out two fence post holes".
As it ages, it keeps its shine. My pieces have turned more of an amber color, still some hint of the orange, but more brown colors come in.
robo hippy
Very good to know John, thanks !!!
Ray
Re: Just keep in mind the old saying,.......
:D Good one Jamie!
