grinding wheel
Doug Adams
What are your recommendations for the type and grit of grinding wheels
Thanks
Doug
grinding wheel
Doug Adams
Thanks
Doug
Re: grinding wheel
robo hippy
http://www.d-waytools.com/
These to me are the future of grinding for woodturning. They are spin balanced. They do not need to be dressed or cleaned. They do not change size. There is no risk of them ever blowing up. The 80 grit is very aggressive, and the 180 grit is comparable to 120 aluminum oxide. They aren't cheap, but worth every penny.
Just a satisfied customer.
robo hippy
Re: grinding wheel *LINK*
Greg Haugen
Doug,
For grinding wheels, I'd recommend the Norton 3X "k" grade wheels. They're a great wheel and only a little more than standard "white" wheels. I've also used the "pink" wheels from Woodcraft and they're good as well. Quite a few places carry the "k" grade 3X wheels and here's another option. They carry everything "sharpening". I'm currently using standard white wheels that are 120 and 60 grit. I'll get new ones once I use them up. They do sharpen nicely and I don't see a point in replacing wheels that work just fine, I dress them more often but they sharpen the tools just fine as well.
If price is no factor, the diamond wheels are becoming a popular choice but I've heard mixed reviews.
The best option is the one you use, keep it properly dressed, and use a light touch when "dressing" your tools' bevel.
Sharpening Supplies
Re: grinding wheel
Fred Holder
I've been using Diamond Grinding wheels from Andre Martel in Canada for over two years now. I have a 100 grit on the left side and a 360 grit on the right for final sharpening. These have a couple of advantages, they do not have to be dressed, they are balanced, and the 360 grit wheel gives an excellent finish grind. One other benefit is that the wheel is 1-1/2 inch wide, this does require one to remove the guards from the grinder, but there is no danger from the wheels exploding. I should mention that they are expensive and at this time I do not know how long they will last. I've only had them for about two years. I would hate to have to go back to the old white wheels or wheels narrower than 1-1/2 inches wide.
Re: grinding wheel
Bill Howatt
I also have read mixed reviews about the diamond wheels but given the price and my requirements it is a non-issue for me.
Another vote for the Norton 3X blue wheels. Far superior for sharpening turning tools than the too soft white wheels.
Bill
Just one opinion... *LINK*
Chuck Jones - West TN
I make no pretense at being a sharpening expert, but I have been very satisfied with my Norton-SG wheels. I use the 80 grit. Cost $105; about twice the price of the Norton 3X. Available at Packard, just search for "Norton SG". Comes in multiple sizes and grits.
The first one was about three years old when I damaged it in an accident (unrelated to the type of wheel). I actually redressed the first one and it worked fine, but folks on this forum convinced me I should not continue to use it. I kept it as a backup.
I have a diamond wheel from Woodcraft that I have used a year or two and love it except it is wearing out. There is a visible grove in the center. Could have been I spent too much time in the center; I don't know. It puts a really great honed finish on the tool. I'm still able to use it; just have to avoid the center.
Packard
Re: grinding wheel
Doug Adams
Thanks to all
Doug
Good article on grinding wheels
David Walser
Doug,
If you're a member of AAW, there's a good article on grinding wheels by Bill Neddow in the April 2011 issue of the American Woodturner. (The article is available online for AAW members. Non-members can probably borrow a copy from a member.) Bill discusses the types of wheels available today, outlines the pros and cons of each type, and tells you how to read the manufacturer codes for each wheel type. I highly recommend the article as a resource.
One thing I learned reading the article: Diamond wheels are not the "ultimate" answer to sharpening lathe tools. Steel and diamonds react chemically to each other. The carbon in the diamond is attracted to the steel, causing the diamond to break down. The chemical process is accelerated by the addition of heat from grinding. Thus, sharpening on a diamond wheel will quickly "polish" the wheel, causing the effective grit size of the wheel to go from 80, to 120, to 240, etc. For this reason, according to the article, diamonds are not used in industry to grind steel. Instead, CBN wheels are used.
