Delta 46-460 review *LINK*
I bought one last week and finally had time to play on it. Mostly I have great things to say about it. There are some things I would like to change but they are minor.
First off it was absolutely dead on accurate. A dial indicator on the spindle didn't even move. That's a lot less than a thousandth of an inch runout. The tailstock was dead on. The motor and spindles were adjusted dead center and tension lever works perfectly. It only takes one lever to loosen and tension the motor to change belts. There are 3 pulley settings. This is the variable speed model. It has enough power I will probably only use 2 of the pulley settings unless I really hog down on a full size bowl.
The tailstock and headstock slide well and lock down well. I've turned on a couple of these machines where the banjo kept wanting to come unlocked. Mine works great so it's probably just the adjustment on the bottom that makes them lock down correctly.
It has indexing which I will of course use. I would like to convert it to 1 1/4 x8 tpi. Fortunately I'm going to visit Bestwoodtools this saturday so I'll do my best to convince Vic to build me what I want. I might be able to do it on my lathe but Vic's will be dead on accurate.
I bought the stand. It's adjustable for height but does not have a lot of adjustment. If your tall you may have a problem. I put wheels under mine which raised it up to just perfect height.
Now the little nit picking problems. The knock out bar did not fit the holes in the spindle that you use to hold it while removing the chuck. It was off .020". I guess maybe the hole weren't drilled right because the knock out bar looks like it's machined and chromed perfectly. I just ground the end down a little and it fit perfectly.
The index pin sticks out too far and you can pinch the heck out of your finger when rotating the handwheel. It can be done but takes a learning curve and some concentration to keep from hitting it. Maybe the knob can be shortened and the handwheel extended to prevent this. It's not a big deal but could be done better. The tool rest post is almost too good of a fit. It's a little hard to adjust up and down. It may wear down but if it doesn't in week or two I'll hit it lightly with sandpaper to make it slide better.
All and all this is a great lathe. The only mod I'm going to do is come up with some way to remove and install it from the stand quickly so I can haul it in my car. I'll put knobs on the stand instead of nuts and that way I can dissassemble it for traveling. My mini lathes were OK but underpowered so it made the demo's go slow. With this lathe I'll be able to get rid of wood pretty quick which makes the demos go smoother.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=packard&Category_Code=lathes-delta
Re: Delta 46-460 review *LINK*
Mike from St. Clair Shores
John,
This is the lathe my club bought for our small lathe.It works great and one of our members built a steel stand that has shelves and locking doors on it. We can keep all the accessories and a face shield in it. It also makes it very heavy so some eccentric turning can be done. I think you will like it.
Mike
Chuck Bjorgen
Your review, John, pretty much is the same as mine. I bought my 46-460 earlier this summer after deciding to move my turning operation from my basement to my garage. I sold my Vicmarc VL-200 shortbed to a friend and bought the Delta Midi along with the bed extension and the complete stand setup. Part of the lathe change was the frustration in not having the bed length to do turning operations that required that. I'm not really into long spindles but I did want to start making things like pepper mills, etc., that needed extra length for drilling.
My lathe tail stock was dead on as well. I decided to go with the complete Delta stand so I could get to turning during the summer. It has done the job for the money although I wish I'd had the time to build a heavier stand out of wood. There really is no way to add additional weight to the Delta stand with extension.
I'm strictly a hobbyist with no desire to sell my wares. My preference is to make smaller items such as lidded boxes and smaller bowls to give as gifts. The 460 has adequate power for those tasks and the ability to quickly change the spindle speeds on the 460 is wonderful!
My reason for moving out of the basement was a question of wood dust but that move will also limit my turning during the winter months here in Minnesota. If need be, I suppose I can move just the lathe itself back inside. The dust question along with some health issues caused me to stop turning during the past three or so years. I'm happy to report that tool handling skills do not erode once learned.
Karen F.
Our club (San Diego Woodturners) has bought 7 of these lathes for our classes and 6 more for working with the Wounded Warriors in the Military. We have them set up with the factory stands except one of our members designed one for turning while seated for the military classes. They do need some lifting blocks if you're in the 6'2" plus crowd.
We have had some of the same problems especially with the spindle lock. It is difficult for large fingers to get to it. Make sure it is seated back in the grooves when unlocked. We believe one slipped back into the locked position while moving and burned the motor out in seconds. Delta fixed it without question which was very nice.
We have been using them for over a year now and there have been no other significant problems. The variable speed is great too. This midi is able to slow enough to chase threads on it. We couldn't do it on the Jet Minis we used to have.
Overall, great lathe. I plan on buying the same set up to use on our travel trailer when I get to retire next April. Counting down the days:)
Since I haven't taken the headstock apart yet I have a question. Is the Index lock strong enough to use as a spindle lock. It is on my Nova Comet but I don't know what material they have used on the Delta. So far I have used the Knock out bar and holes in the spindle flange to remove my chucks and faceplates.
Sent and e-mail to Delta to ask about the lock
Phil Stivers
Phil Stivers
Karen and I are club buddies :-) I think that all of the members use the index pin as a spindle lock with no apparent issues. I use it that way on my own machine also.
I also bought one for my shop and put double locking caster on it. The side benefit of that; it's now the right height.
I built a set of Phil blocks for the club's lathes. 4 x 4 pieces to go under each foot.....save my back.
Carol Reed, Strawberry, AZ
Phil blocks for Phil height makes me need a step ladder! :D :D
Got this message from Delta
Thank you for contacting us here at DELTA. The DELTA brand was purchased from Stanley Black and Decker this past February. Since we inherited the lathe from the previous owner, we had noticed that the pin and wheel were a little close. This is being addressed and so will the size of the bar vs. hole size in the flange. Always use the bar. It is more easily replaced and less expensive to replace than the pin assembly. Thank you for pointing this out.
Thank you for being a DELTA customer!
Customer Care Services
Delta Power Equipment Corporation
Walt Bennett
Walt Bennett
I've been using (and evaluating) them for about three years and totally agree with your evaluation. I've posted pretty much the same here and on AAW's site for quite a while. Interestingly, I've not seen much about the equivalent Jet. Anyone got something to say about it?
Walt Bennett
Walt Bennett
Forgot to mention that my most favorite lathe is my Stubby, but the 46-460 comes in a close second (portability!).
Ron McKinley
I've had that lathe since April of '10 and really like it. I just saw a review of it in American Woodworker Magazine and they considered the indexing pin as a spindle lock also. I don't think it's strong enough for that so I just use the knock-out bar in the hole on the spindle stretched over the toolrest to break loose a balky chuck or faceplate.
I really like and use the reversing feature when sanding. It has two drilled and tapped holes in the side of the belt cover that I can't figure out. I've also glued several permanent magnets on it for holding chuck keys, etc.
Like yours, mine was dead on and still is. Mine is mounted on a Harbor Freight hydraulic cart so I can adjust the height since I'm now confined to a wheelchair and that works out well. A really fine machine......Ron
keith zimmerman, Phoenix, AZ
I've had my 46-460 since they came on the market. I had waited for what seemed forever after I first read about it and was extremely surprised that it met and exceeded my expectations. This is a really great lathe.
I built a custom height bench to mount mine on. It is designed to put the lathe at exactly the right height for me. I also purchased a Monster hollowing setup for it and Randy set up the mounting bracket specifically for the lathe.
I've only found two minor issues with the lathe. The first was that the banjo seemed determined to come loose while hollowing which an adjustment fixed. The second was the same thing John mentioned with the knockout bar. Initially, I used the index lock to lock the spindle, but, after reading that it could cause premature wear, I switched to using one of the tommy bars for my Nova chuck, which work just fine. I do not have any issues with the space between the index pin and handwheel as others have reported.
When I moved to Phoenix, I packed it in the original box and have it set up and the alignment is exact. It is now mounted on a new bench and works just fine.
keithz
Karen F.
Yeah- Phil has his own feet (lathe risers) and he now has his own chair since he broke that last one he used.
