30 minute bowls
Those of you who have been turning awhile can relate to this. I remember when it took 4 hours to make a hand mirror and Who knows how long it took to make a bowl. forever comes to mind. I turned a 6" bowl last night that included a shaped foot for carving 3 feet in 30 minutes. That included sanding and changing the shape of the curve at the bottom when I turned it around.
Not trying to brag just stating that after you've turned enough of these you start to get the cuts down so you don't waste any time. Your tools are sharp and you quickly waste away material to get down to the final shape. Just to learn more about the tool I used the Hunter Hercules to rough out the interior. That went really fast. Then I made about 2 passes down the sidewall and about 4 or 5 across the bottom to get the shape and thickness right.
I'm not anywhere near as fast as Glen Lucas or Mike Mahoney but I can now see how they got there.
I spent about 30 minutes roughing out the 3 feet with a hand carving tool and shaping the bottom of the bowl. Tonight I'll shape the feet with a rotary tool which should only take about 45 minutes or so. Then a little hand sanding and it will be done.
