The #3 Hunter Hercules tool *LINK*
Ed Moore in SW VA
I just watched an interesting short video of this new Hunter tool. A new turner who wants to avoid purchasing lots of tools would do well to consider purchasing this tool. It shows smooth cuts on the inside and outside of a bowl as well as smooth cuts on a chunk of walnut with lots of knots in the spindle orientation. Basically this is a solid rectangular cross-sectioned tool with the round carbide cutter in a drop-nosed position. It is used horizontally so the tool is always presented to the wood at the correct angle or orientation.
Mike Hunter and Mike Stafford are about to leave for Norway to go on the Norwegian Woodturning Cruise. They will be demonstrating the complete line of Hunter tools. I hope that they have a fabulous time and that they sell lots of Hunter tools.
Mike Hunter will be visiting the Smith Mountain Lake Woodturners club on September 8 to do a demo on his tools. We are looking forward to his presentation.
Ed Moore
#3 Hunter Hercules Tool
Re: The #3 Hunter Hercules tool *LINK*
Chuck Bjorgen
I bought this tool from Mike after he demonstrated it's use at our Minnesota Woodturners Association meeting last week. I tried the tool a bit the next day but after watching the video, will try a bowl from start to finish as the video shows. My initial reaction is that I need more practice with the tool. The video did help clarify a few things for me though. Specifically, holding the tool parallel to the floor is important. Thanks for posting the video link.
Mike, I was in on some of the early development so I have played with various versions and now of course the final version. It is an extremely easy tool to use and leave a great finish. You use the tool much like a scraper but it's seems harder to get a catch. It actually cuts the wood instead of scraper due to the angle of presentation of the cutter.
When using the tool you can cut with all sides, however when used at the 9 and 3 position it will try to pull the wood into the cutter and can get what sort of feels like a catch. On thin pieces it would possible flex the bowl enough to pull it apart. However when used from the 10 to 2 position it is extremely easy to use and very safe.
It has some advanced cutting capabilities that the flat scrapers don't have. I plan to do a video but it might be a week or two away, my real job is getting in the way. You can rub the bevel on the front just like you do with the nose of a bowl gouge. It will give you a cleaner cut than most bowl gouges in this mode. Since the effective bevel is 83 degrees you can cut the bottom of very steep sided bowls and still be on the bevel the whole time. It is great at this. Of course you can also cut shallow bowls inside or out using the same technique.
You can use it as a negative rake scraper by tilting the tool and scraping with the bottom lip. This is much like using the lower lip on your bowl gouge. It scrapes very clean because the included angle on the lip of the cutter is somewhere between 25 and 30 degrees (it's sloped so it's hard to read).
I think it is a wonderful tool. The beginner can just grab it and go. The advanced turner can use the more advanced techniques to get cleaner cuts or refine the shapes.
When you are roughing a bowl with a really out of round protrusion this tool is very easy to use and take a lot of the beating out your shoulder. you do have to advance it carefully but the mass of the tool takes a lot of the force.
Don Leydens
Don Leydens
I've used this tool also, and it really is easy to use. Lots of fun, actually. The beefy shape keeps vibration down and the tip actually cuts rather than scrapes. I keep finding more cuts that this tool is really good at.
Stuart Johnson
What size is the shaft and will it fit in most of the standard handles? I'm making the guess that it is round.
Mike Stafford
It has a 5/8" shaft
Mike Stafford
I am finding more and more uses for this tool myself.
Like John said if you start with the heel just rubbing the roughed out piece and gradually raise the handle until the carbide cutter begins cutting you can peel away fine shavings and remove any tearout from end grain on bowls. I was amazed by the clean cut the tool provides.
It will also do an incredible job on plastic and composite pen blanks without chipping. The finish off the tool will greatly reduce your sanding time compared to a negative rake scraper which is what I was taught to use on the composite and plastic pen blanks.
The massive shank takes a beating when rounding up out of round stock and removes the gnarl from gnarly wood while taming the most unruly piece of wood. I also like the fact that you can cut in any direction with ease.
I don't often have a need for this feature but in the latest Woodturning magazine there is an ad from ToolPost where they turned a concrete paver with a Hunter tool. So for those of you who turn root burls this tool may be a problem solver for embedded grit and stones.
Re: It has a 5/8" shaft
Now that's something I haven't turned yet. I'll have a bunch of pavers soon if anyone want's to try it. I can imagine would probably turn stone but I'm pretty sure it would chip the edge. For turning concrete I would think a much more blunt edge than the Hunter tool would be called for.
The Hercules has a 5/8" square shaft and if you order it unhandled has a 5/8" round turned on the end.
Keith Tompkins
Keith Tompkins
Hey Ed, I checked out the video last night. It seems to take far longer to turn a bowl than with a bowl gouge, as the cut is fairly shallow. However, I bet it would be ideal for refining the shape after turning with the gouge. How does it cut on wood that normally tears out?
Ed Moore in SW VA
Keith,
I don't have this tool, I only was aware of the video. But I think your observation about it being a good re-turn tool may well be spot on. It will be interesting to see Mike's demo in September.
Ed
GaryG in MD
It looks like a great tool that would have a number of applications...
I like the idea that you can start a cut at an edge with no kick back.
It's also nice that it can go rim to bottom in one cut.
BUT, I would think it would be harder to get a nice straight, continuous curve with this tool (that does not have a bevel moving in the direction of the cut) than it would with a bowl gouge. I think if I were to use it, my curve would be bumpy with a number of small depressions. I also agree with Keith's comment. ...Gary
Mike from St. Clair Shores
I thought the tool looked like it worked great in the video. Thanks Ed for that link.
Mike and Mike I'm totally jealous of you guys going on the Norway cruise. Have a great time and don't forget to take your Wood Central hat and get a good pic with it for us.
Mike
Not if you purposely take a large cut. I haven't tried it side by side with my bowl gouge but I'm pretty sure I can turn just as fast with it. However speed of course isn't what it's all about. This tool is about giving beginners an easy tool to use so they can get into wood turning and enjoy it. Yea I know they should be learning to use the bowl gouge and I'm all for that as well. However a tool like this will get them excited about wood turning. then as they attend club meetings and learn more they will hopefully want to learn the bowl gouge.
Mike Stafford
My bags are packed....
Mike Stafford
and so is my WC hat. I just hope I can remember to take pictures of it.
Craig Daymon
I watched the video and it does look interesting, but the tool use in the video looks VERY controlled.
If it is suppose to be so easy for a beginner, I'd like to see how it handles when it is presented slightly off of horizontal or at a greater tilt than the recommended maximum tilt of...5 degrees(?).
I also agree with Starry's comments above that it does not look like the best tool for getting a smooth sweep from rim to center on a modest sized bowl as you are not riding the bevel. (It does in the hands of the demonstrator, but most things do.) The one place that I would expect it to be very useful would be removing the nib from the center, but in the video that looked like a problem area for the demonstrator.
I'll have to get some hands-on time before I'd pick one up.
