Grinder wheel truing video *LINK*
Re: Grinder wheel truing video *LINK*
#2Re: video
Jack Savona
John, your video was very concise and clear. It'll make me look more closely at my grinder. Thanks! All your videos have been a helpful addition for turners everywhere.
I have to say I cringed a bit when I heard you talking clearly as all that silica dust went into the air. I assume you didn't have a respirator on. Ever since I read that dust from the grinder is way more harmful than sanding dust, I always use respiratory protection when cleaning my wheels. You just can't cough those particles up. They're there for good.
Anyone else use a respirator when truing or cleaning?
#3Re: video
Jack I usually have the guards on the grinder and a shop vac hooked to the dust collector shoot when cleaning or truing. Obviously I removed them for the video and should have said so. I wasn't awake yet.
In a WoodCentral Window
steven antonucci
S
Jesper, Denmark
John, You do some very nice and understandable training videos.
Specifically on th� truing of the wheel, the diamond does not have to be at an acute angle to the wheel. 90� is just fine and makes it very easy to hold a single point diamond by hand and sweep it gently across the face of the wheel, supported by the Oneway baseplate.
This was the real reason for building the suction system on my grinder.
#6Re: Grinder wheel truing video
robo hippy
When I had conventional wheels, I had the T type diamond dresser and the Veritas platforms. I would true up the sides and face of the wheel by gently easing the T into the wheel, taking off the high spots, till the wheel ran smooth. It can be done, just like taking off the high spots on a turning.
I have had matrix type CBN wheels now for 5 or 6 years, and now also have the D Way tools CBN wheels. Never have to balance or true them up ever again. Worth every penny of the cost.
robo hippy
#7Re: Grinder wheel truing video
When I first started truing the wheels I used a hand held single point diamond. I found that using it at an angle gave me more control. That's the reason I say that the angled cutter has more control. In reality in careful hands both work quite well. The Gieger definitely is easier to control than my homemade version. It might be the weight as much as anything.
Don Geiger
Nice video John!!!
I would like to explain the purposes of the angled position of the diamond I use on the Tru-N-Dress tool:
Even though they are harder than the aggregate of the wheel, diamonds wear with each contact. If the diamond were placed perpindicularly to the wheel, the diamond would wear flat. This will make the diamond wear out prematurely and it becomes less efficient with each use.
I place the diamond at an angle to the wheel so only the left side of the diamond contacts the wheel. In this position, a tiny facet it produced on the diamond with each use. The diamond is mounted to a threaded shaft and is rotated with each adjustment. This creates a cone shape on the diamond. The resulting cone shape is an efficient shape to cut the aggregate of the wheel and the life of the diamond is extended. Think of it as sharpening the diamond with each use instead of making it duller.
Another point I would like to make is in regards to diamond size. All the manufacturer's sources I can find state that the proper diamond sizes relative to wheel sizes are as follows:
1/4 ct. use on wheels up to 6" diameter
1/3 ct. use on wheels upt to 8" diameter
1/2 ct. use on wheels up to 10" diameter
Please let me know if you or any of the WC members have any questions or comments.
Don Geiger
#9Thanks Don, makes perfect sense
#10Great Vid - one edit!
Ricc havens
John from my newbie turner perspective its a great video. The only correction I would make is the website at the end of your video. It's
http://www.geigerssolutions.com/
you only have one "S"in the middle which took me via an automatic re-route to an accounting website ending in .net
Thanks
Ricc
#11Great Vid - One correction
Ricc havens
I tried posting this earlier and it didn't show up so my apologies if it shows up as a double post.
As a newbie I really liked and appreciated the video.
The only correction I would make is to a web address you show at end of the video. the correct website is
You only show one "S" in the middle and that took me via a automatic re-route to a accounting website
Thanks again!
Ricc
#12oops-thanks ricc I'll try to change that tonight
#13Re: Grinder wheel truing video
Barbara Dill
Great video John....thanks.
#14Thanks John, picked up a couple of good tips!
Bill Howatt
