I don't want to Highjack Avalon's - Pendants
Randy Gleckler
I don't want to hijack his thread.. so Starting here.
How are those pendant's mounted on the block? So I'm assuming an angle, turn basically a bead, then finish and dismount Right?
Randy Gleckler
Re: I don't want to Highjack Avalon's - Pendants
Randy I'll try to explain but I haven't turned these things in months now. I use double stick tape to attach the wood to the waste block. I use a rectangular glue block and stick the pendant wood to the middle.
I turn the outside diameter. Then I shift the wood up or down. Now I drill a hole off center at this point. Then I shape the hole using the toe of a skew as a scraper or use a detail gouge and turn it. I round off the underside of the drilled hole as well. The detail gouge with the flute pointing toward 9 oclock and cutting with the lower lip is the safest way to do this.
After the outside was turned and the hole drilled off center and turned I try to decide what details to turn into it. These can be done by moving the waste block up or down. I rotate the chuck by hand and draw pencil lines if I need to on the pendant.
Here is a sample of one of the early experiments. You'll notice this one doesn't have any taper to it. To get the taper you can simply move one end of the glue block out so it doesn't seat all the way down in the chuck.
Re: I don't want to Highjack Avalon's - Pendants *LINK*
Ed Davidson
Here's a how-to video - link below.
Pendant Turning - part 1
Mike from St. Clair Shores
Ruth Niles was selling the pendant chuck for Richard Joyner (i think that's his name) I got one last year, watched Ed Davidsons videos and began making them.
After doing a club demo, i think club members bought over 20 of the chucks from Ruth. It's inexpensive and they are fun to make.
ive been Highjacked
avalon
i like both richards and the axminster... i want to do both and was hoping a chuck did both..
john.. your double stick tape... i've been using something from lowes and it works fairly well, but it occasionally lets go of the pendant... just wondering if there was a difference...
you need cloth backed double stick tape *LINK*
This stuff holds tremendously well. Apply it, then clamp the pieces for about 30 seconds. To remove the piece put thin bladed knife like a butter knife and sort of saw down through the joint. Another method is to use a wire with 2 handles and use that to saw through the tape joint. Either method works and keeps you from breaking pendant.
the tape is expensive but it lasts forever. I use it to glue platters to scrap blocks for turning as well as these small things.
http://www.woodturnerscatalog.com/store/Adhesives___Fastening___Double_Face_Tape___double_face_tape?Args=
Why Full ROUND? *LINK*
charlie belden
If you're going to do jewelry, why stop at full round pendants. And why not include some articulation?
Idea for Production Piece
