A55 Smoothing Plane
lathe mobility
lathe mobility
lathe mobility
Skip Beardsley
I have found I want to try turning out on the end of my new 3520b which means I need to be able to move the lathe ninety degrees while turning and then move it back to sand and finish due to the position of my dust removal system.
Thus the question, does anyone have a wonderful system for moving a mustard monster, either shop made or store bought?
Skip
Re: lathe mobility
Re: lathe mobility
Skip I haven't seen anyone do it with a lathe but they make air lifting devices for moving machines. I've always wanted to build one. You could just turn it on, move the lathe and turn it off so it would settle down.
Re: lathe mobility
Roger in MO
Re: lathe mobility
Roger in MO
We used commercial units to move 12'x25'x10' steel structures. One man could easily move it (don't push too hard--it also has to be stopped :)
It required a very clean, smooth floor.
Roger in MO
Re: lathe mobility
Dennis in Southern Oregon
Re: lathe mobility
Skip, as and alternative, have you considered making your dust extraction set-up more flexible? My shop has a plumbed dust extraction system and the lathe station terminates in an 8-ft length of 4-inch flexible hose that can be moved as needed. About a foot from the he business end of the hose there is a band clamp onto which I have epoxyed a strong rare-earth magnet. I can can stick the magnet to any part of the lathe that I like and get dust extraction wherever I need it.
Dennis
Re: lathe mobility
Re: lathe mobility
ihmserv
you can check out the suggestions on the mustard monster site.
https://docs.google.com/View?docID=d4b7vjd_19f4xnj9&revision=_latest
IAN
Re: lathe mobility
Re: lathe mobility
That would be great for a mini lathe but it's a little difficult to pick up a 750lb Powermatic a put it on top. A motorcycle lift might work if your 6'8". Even that would place the lathe almost a foot higher than normal. :)
Re: lathe mobility
link does not work
Re: lathe mobility
oops you need a password
Re: lathe mobility
pneumatic movers  *LINK*
http://www.rotairsystems.co.uk/airskates.html
Re: lathe mobility
Richard Allen
Re: lathe mobility
Richard Allen
The table supports the "middle" of the lathe under the ways. The table would be removed when the lathe has been moved.
You might need to build a structure on top of the table to make up the difference between the table top and the underside of the lathe ways.
Re: lathe mobility
Re: lathe mobility
Dale Miner
Richard has it right.
I moved mine from a parking lot, into an elevator, and from the elevator to the demo area in the basement of a church with another turners hydraulic table. If memory is correct, it just went under the middle of the lathe and had enough lift to pick the lathe up without any additional blocking. We moved the headstock and tailstock in order to get the weight of the lathe fairly well centered on the table.
Re: lathe mobility
Re: oops you need a password
bill Crommett
Did you consider adding an extension to your dust collector system ?
Re: lathe mobility
Dick Hines
Dick Hines
One of the clubs I belong to has a PM. We installed wheels that Woodcraft sells to the legs. They have locks so when the lathe is in place we just lock the wheels. The lathe is very stable and easy to move.
The only problem is if the user is vertilally challenged they my need a platform to stand on.
Re: lathe mobility
Re: lathe mobility
Guy Bratt
Our club uses a scissor table cart for our 1642 Jet. Moves the lathe easily from the trailer down the ramp into the building and back with no trouble. It was about $200 from HF at the time of purchase. and you have a rolling work bench between times.
